a/c not blowing air at all
Hi guys, i have another problem to fix! My a/c system isnt working and i dont know where or how to begin troubleshooting. The car has all a/c lines/ condensor/compressor w/ belt, but it doesn't blow air inside the car even though i've moved the slide to 4 on the control. heres what i know:
-was told when i bought the car the a/c wouldn't work(well he was right lol)
-verified 99% of a/c components are there (everything seems in place)
-a fuse or two may be missing from under dash panel
-no blown fuses under hood
- no pressure at all inside a/c lines
-Mike
-Mike
no, i just dont know where to start, not sure what to check first. when i move the slide from off to 1-4 nothing blows out of my vents. where/ how can i begin to check the fan for the car? btw its a 94 civic
i dont hear anything, also i noticed none of the button lights turn on when buttons pushed; no green light for a/c button or orange lights for recirculate, etc.
i am missing dash fuses 13 & 20 (in case they're related)
but no fan noise or air flow whatsoever
Then that's not a problem with the AC...its a problem with your fan not working, which is a different issue entirely (albeit much simpler).
Time to start checking fuses.
**From the FAQ**
16. Climate Control
a. Blower
Removing and Cleaning Blower Motor (whole thread)[*]
Fix Blower Motor That Only Runs On Certain Speeds[*]
Climate Control Blowing Wrong Direction on 96-00 Civics[*]
Installing Cabin Air Filter on 96-00 Civics[*]
99-00 Civic Climate Control Into 96-98 Civics[*]
92-95 & 96-98 OEM EDM Civic Cabin/Interior Air/Pollen Filter Retrofit
**From the FAQ**
16. Climate Control
a. Blower
Under-dash Fuse 13 (7.5A) is related to the A/C thermostat, heater control panel, etc.
alright, excellent! just popped a temporary 10a fuse in #13 and BAM blows air now!! its weaker than should be on all 4 settings though, i pulled the blower motor resistor and its looks pretty ... charred i think would describe it, real grey and the ... the stuff that kinda looks like glue on it is cracked. you think if i replace it itll fix the air flow prob?
