Need help car wont start now after swap. thanks
Old Jun 16, 2014 | 10:17 PM
Manifest113's Avatar
Default Need help car wont start now after swap. thanks
Hey everyone im am having a issue with my car starting after my build.
I have a h22a1 swapped 94 cx hatch. Hondata s300 ecu. car ran and drove fine for over a year with this setup and no issues. I pulled the motor and put a h22a block in with a pnp h22a1 head and turboed the car. same wiring harness and everything that was used before no wiring was changed minus the injectors clips. i went from using stock injectors to using precsion 880cc injectors, larger rail etc. i know timing is correct and the dizzy is new so are the plugs and wires.
The issue is the motor will turn and turn but not start. i have tried everything i can think of and double checked everything but nothing. and i noticed the ecu/hondata light will be green but when i turn the key it turns red till i stop trying to crank the motor. i swapped ecu out to see if anything would change and same result. i had the ecu uploaded with a basemap from a shop that will be doing the tuning but the second ecu i have was used for a h22 and has a map and it wont start either. please and help would be awesome bc im at a loss. also do i need to be using a resistor for the injectors? i have a p06 and a p30 ecus. both have been used for this motor and chassis. thanks
Old Jun 16, 2014 | 10:26 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Re: Need help car wont start now after swap. thanks
have you checked fuel and spark? double check mechanical timing.
Old Jun 16, 2014 | 11:11 PM
yea mechanical timing is dead on. fuel pressure is good and constant. spark is fine. makes no sense
Old Jun 16, 2014 | 11:14 PM
double check grounds.
Old Jun 17, 2014 | 12:20 AM
yea that was my thought process. i think i got them all but maybe i missed one.
Old Jun 17, 2014 | 12:51 AM
thermostat, trans. get at it.
Old Jun 17, 2014 | 07:17 PM
So the issue was bad wiring n thermostat ground came lose some how. Car fires right up now
Manifest113
Engine Management and Tuning
Jun 29, 2014 04:45 PM
97uswagon
Dec 18, 2011 07:49 PM
1badda
Aug 26, 2010 06:48 AM
fastludeh22
Feb 13, 2003 12:24 PM
