honda civic 98 ex with idle, stall, and stumble problems
Old Jun 15, 2014 | 10:09 AM
luisotero_15's Avatar
Icon2 honda civic 98 ex with idle, stall, and stumble problems
hi guys I have this honda civic 98 ex manual that has stall problems, stumble under acceleration full trotthle of I put complete new distributor, spark plugs, tps, map sensor, IACV, belt timming, head gasket, intake manifold gasket, manifold gasket, fuel filter, main relay, fuel pump, fuses, everything has been put brand new, and the car still have problems someone could give me a help with suggestions. the car turns well and while in parking or neutral is good, once you run and sink the full throttle as it stalls and stumble, all is well until you stab the throttle completely runs out of power and onlys tiembla.the codes That show o2 sensors because the car dosent have the catalityc but is nothing important to make my car stall and stumble under full trotthle acceleration.
Old Jun 15, 2014 | 10:15 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: honda civic 98 ex problems with idle ,stall,stumble
Can you please take some time, edit your post and break it up into coherent sentences and paragraphs?
As it sits now, very few people are going to want to sit through that painfully to read, jumbled together, run on post and help you.
Old Jun 15, 2014 | 11:00 AM
marc59's Avatar
Yeah I see what you mean tomcat39 lol...ok since you replaced all of that and your ecu is only giving you the o2 codes which wouldn't usually make it do that...check your ground on the thermostat housing and check the knock sensor but to me it sounds like the ground
Old Jun 15, 2014 | 11:34 AM
sorry about that guys im a spanish guy so my english is real bad i know,my ground under the thermostat is good,my car dont have the knock sensor but i dont think that is the problem because my brother in law had the same car without the knock sensor and runs good.
Old Jun 15, 2014 | 02:20 PM
grumblemarc's Avatar
The Grumpiest
Mechanical/ignition timing? TPS calibrated? And don't say it's "fine" or "good". MAP and TPS sensors plugged up wrong? Firing order correct?
Old Jun 15, 2014 | 02:51 PM
marc59's Avatar
Yeah id check the map and tps to make sure the plugs arent reversed
Old Jun 15, 2014 | 03:31 PM
tps its already calibrated and the plug is firing and the same with the map sensor good and firing.i check the timming and its perfect . i hear something about valves and piston rings did somebody know something about that.or what about the ECU???
Old Jun 15, 2014 | 03:45 PM
The Grumpiest
And he says it anyway. Good luck. And you need to get a cat on that car.
Old Jun 16, 2014 | 04:36 AM
Former User's Avatar
If punctuation is your weakness, then write in bullet points. I edited your first post as an example.
98 Civic ex manual
Problem - stalls, stumbles under acceleration full throttle
Parts replaced - complete new distributor, spark plugs, tps, map sensor, IACV, belt timing, head gasket, intake manifold gasket, manifold gasket, fuel filter, main relay, fuel pump, fuses. All are brand new.
CEL Codes - O2 sensors
Post the CEL codes.
Have you checked the mechanical and ignition timings?
ERICSCEBY
21
Sep 19, 2020 08:32 PM
Green_EJ8
11
Dec 23, 2015 04:07 PM
Afflicted1
50
Mar 4, 2014 09:46 PM
jazz1308
Apr 29, 2013 05:37 AM
Metallica1One
Jul 17, 2011 02:23 PM
