OBDI gsr into 94 vx
OBDI gsr into 94 vx
Alright so i'm basically almomst done with my swap.(awww yeah!) But i haven't connected two sensors which are...
Can anyone mind telling me where i could plug these two in?
I am also getting a CEL 41 code. I know it's the Primary oxygen sensor heater. I'm curious to know if it could be my wire harness since i'm using a vx harness. I know you're suppose to convert your O2 sensor from 5 to a 4 wire but mine already came with a 4 wire sensor. Or since i'm running open headers that could be the reason why it's pulling up the code. Not that i want to run open headers but, i need to go to a muffler shop so they can make me a mid pipe since my mid pipe doesn't reach my headers. any suggestion guys?
Re: OBDI gsr into 94 vx
What was the top one originally plugged into?
Bottom pic looks like the purge solenoid for the charcoal canister.
and no you wont get a cel for running open header header header header header...notice there is no 's' on the end lol
@Juggernaut-CTR thanks for the help! The bottom one is the purge solenoid but i don't know how it was originally hooked up... hahaha! either that or it broke. Other than that, i don't know what the bottom pic is.
@TKATS_EF i already hooked up the speed sensor though.
@HondaPartsHero you literally saved me from a severe headache. hahaha. But, i what should i do with the sensor just leave it out? Thanks for the diagram i found it!
Thanks man i appreciate it. But can anyone help me with CEL code 41? i switched the two black wires of the O2 sensor to see if it did anything and it still had the CEL. I haven't check the continuity because i don't have access to a multi-meter. Would anyone like to share any experiences or even common answers to a situation like this?
Do you have Amy of the vx parts left? I need the 02 5 wire. And the vx manifold and cat? I would love to have them possibly the ecu po7 as well. Let me know thanks.
@Rustyy94cx nope i don't.
So my friend told me to test it out with my old ECU and it still did the CEL 41 code. This thing is killing me guys. I'm guessing i should just buy a new O2 sensor?
bobbysteelz
08-04-2003 05:16 PM
