Broken Coolant Temp Sensor
Old Jun 14, 2014 | 07:24 PM
TNight's Avatar
Default Broken Coolant Temp Sensor
97 Civic 4dr In attempts to replace the coolant temp Sensor I over tightened and it snapped. Think the wiring is still connected inside and there are no leaks .Is there anything I should worry about since I won't be able to get back to this til next weekend.
Over tightened due to me trying to line up the clip so it wouldn't be facing the distributor making it inaccessible.
Old Jun 14, 2014 | 08:23 PM
StayKrafty's Avatar
Default Re: Broken Coolant Temp Sensor
The 2 wire or 1 wire? Assuming 2 from the post, but shouldnt cause any problem. Is the CEL on? If anything, the ecu will default and assume car is always cold and your fuel economy will go down along with a higher idle.
Old Jun 14, 2014 | 11:50 PM
Apple395's Avatar
Be careful,
Your radiator fan will not know to turn on and you could destroy your engine! Keep an eye on your temps and if you get high pull over and turn your car off.
Old Jun 15, 2014 | 03:18 AM
HondaPartsHero's Avatar
Technical Hero
Which sensor?
Old Jun 15, 2014 | 10:27 AM
TNight's Avatar
Coolant temp
Ran it after install fan kicked in after running for about 20 min.
Engine light was on code said sensor was bad hence the replacing.
Did not reset ecu left it to cycle in hopes it shuts off on its on
Old Jun 15, 2014 | 10:37 AM
Technical Hero
The coolant temp sensor with two prongs on the head has nothing to do with the fans only the fan switch on the thermostat housing.
Old Jun 15, 2014 | 11:32 AM
NotARaCist's Avatar
I never narc'd on nobody!
The coolant temp sensor (one pin) only sends coolant temp information to your cluster. The TW sensor sends coolant temp information to the ECU, and the fan switch tells then fan when to turn on and off.
Exactly what is the code?
Old Jul 17, 2014 | 11:05 AM
Rob Green's Avatar
Hey guys, just reading through your posts about the coolant fan issue. my 07 civic coolant fan will not shut off until the battery is dead and engine cold for two days.The fan runs at low speed continuously. After pulling fuses/relays its the right fan that wont shut off (facing car) I'm assuming , after reading the posts, that my problem lies in the fan switch not telling the fan to cut off? So, of I replace the fan switch then the fan will cut off when its supposed too?
Old Jul 17, 2014 | 01:20 PM
Technical Hero
Not saying we can't possibly help but you're in the wrong section for 07 Civics
DisplacedMic
Jul 27, 2016 12:33 PM
jrod9989
Sep 18, 2008 07:18 PM
busyychild
May 6, 2008 11:09 AM
davidluko
Nov 19, 2006 08:27 AM
chattownrexer
Jul 10, 2004 02:45 PM
