Strange bogging/hesitation issue- 95 Civic
Old Jun 11, 2014 | 06:02 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default Strange bogging/hesitation issue- 95 Civic
Hi all, have a problem I am stumped with at the moment. Car is a 95 Civic EX, AT. Motor is a d16y7, all z6 accessory parts, b7 distributor, p06 ecu. Have done this swap before with no issues, and this one was running great until yesterday. It will idle all day just fine, and drive for a short while before any problems emerge. The hesitation/bogging seems to appear when the speedometer cuts out. I replaced the VSS with a spare, same issue. If I pop it in neutral, it will rev fine, and if I downshift like a manual trans, it picks back up, but it struggles to accelerate in drive. No cel's, new plugs, new wires, and swapped distributors with a spare for fun. I think the problem is somehow tied into the VSS issue. Any ideas?
Old Jun 11, 2014 | 06:07 PM
Former User's Avatar
Default Re: Strange bogging/hesitation issue- 95 Civic
Any additional gauge problems or just the speedometer?
Old Jun 11, 2014 | 06:11 PM
Tang87's Avatar
AT Control module? Check wiring? maybe a bad ground?
Old Jun 11, 2014 | 08:20 PM
shotoutacc0rd's Avatar
Does the trans slip? Wouldn't be surprised being its a Honda autotragic
Old Jun 11, 2014 | 08:37 PM
speedometer problem only. all other gauges function fine. bogging clears up after appx. 3k rpms
Old Jun 11, 2014 | 08:53 PM
The VSS gets voltage from 15A dash fuse 24, which also supplies voltage to the main relay and fuel pump. You may want to voltage test both sides of fuse 24. Are voltages similar or different on each side?
Old Jun 11, 2014 | 09:39 PM
i will test it first thing. if not tonight, lol
Old Jun 12, 2014 | 01:30 PM
voltages were both 13 and change.
Old Jun 12, 2014 | 10:17 PM
so with those results, what would the next step be?
Old Jun 13, 2014 | 04:54 AM
The alternator is also on the same circuit. You may want to test it when the problem occurs.
Old Jun 13, 2014 | 10:55 AM
in addition to checking on it, i am going to swap in a known good ecu. will post results.
Old Jun 15, 2014 | 01:30 AM
Tang87's Avatar
Keep us posted. Kind of interested to see what the solution is.
Old Jun 15, 2014 | 01:47 AM
swapped in known good ecu. speedo cut out once, hesitation was still present with speedo operating.
Old Jun 18, 2014 | 03:21 PM
delsolintegra's Avatar
Try spray cleaning the MAP sensor electrical connector with PB Blaster. It fixed the bogging issues with my 93 del sol si auto. When you reconnect the connector use some force. Also replace the vacuum hose line from this sensor to the vacuum canister. It's about a foot long and 1/4 inch. Got it at Ace Hardware.
Old Jun 18, 2014 | 03:59 PM
i actually saw your post searching the forum for similar issues. i did the pb thing to quite a few connectors, seems to still be hesitating a bit. im going to get in this thing with a dmm.
Old Jun 18, 2014 | 05:44 PM
slomofo's Avatar
GDD Member
Do you have a good working MAP sensor laying around by chance?
civic4dr337
Apr 16, 2022 05:59 PM
Chilloutdamn
Mar 9, 2013 11:50 AM
Buddy10297
Sep 29, 2005 07:38 PM
Buddy10297
Sep 8, 2005 06:28 AM
