Rough & Low Idle?
So I got my valves adjusted and ever since my car has had a low idle, its rough and it also fluctuates every so often.. Not sure if this is due to a bad idle control valve or what? Car is a 94 dx 1.5L with 180,000 miles. Any ideas? suggestions?
Inspect for vacuum leaks, and or vacuum hoses that are not plugged in. If that checks out, clean your FITV and IACV.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/ - How to Clean your IACV
You can try to google video's as well on how to clean your FITV.
