v-tec solonoid oil leak?
Old Oct 30, 2002 | 05:10 PM
JICsube's Avatar
Default v-tec solonoid oil leak?
so i was intalling my header when i noticed there was oil stains all over and its coming from my v-tec solonoid, is this normal in hondas (motor is a b18c1) time too spend more money fixing up this car with many troubles
Old Oct 30, 2002 | 06:00 PM
Malice's Avatar
New User
Default Re: v-tec solonoid oil leak? (axion7606)
ive never seen oil come out of mine. take it off and see if the screen is clogged.
Old Oct 30, 2002 | 06:08 PM
Jesse H's Avatar
take it off, clean the screen, and find out if the dealership sells that gasket alone. It's probably inexpensive.
poison's Avatar
Default Re: v-tec solonoid oil leak? (MaliceGSR)
No. This is not normal, I would take off the VTEC solenoid and check the filter and make sure all is clean, as well as the bolts that bolt the solenoid on the head is properly torqued.
Old Oct 30, 2002 | 06:18 PM
JICsube's Avatar
Default Re: v-tec solonoid oil leak? (poison)
sweet, thanks for the replies- gonna check it out this week!
Old Oct 30, 2002 | 06:48 PM
tinkerbell's Avatar
Default Re: v-tec solonoid oil leak? (Jesse H)
that screen/gasket is like $15US???
not inexpensive, but probably will stop your leak problem (it stopped mine )
t..
Old Oct 30, 2002 | 07:16 PM
Kamin's Avatar
Default Re: v-tec solonoid oil leak? (tinkerbell)
t..
the SCREEN is 15$
the little f*cking screen.
for a cheap alternative
use some liquid gasket. make sure you put it on the OUTSIDE of the gasket, not where oil is.
Old Oct 30, 2002 | 08:32 PM
AtomiK_EK's Avatar
It might not be the vtec solenoid. It could possibly be the cam seal that is right next to it. Thats where my oil was leaking from before.
But if oil is all over the solenoid, and not just running down the side of the head, then forget about what I said.
Old Oct 30, 2002 | 08:37 PM
tinkerbell's Avatar
Default Re: v-tec solonoid oil leak? (AtomiK_EK)
good point
give it a good clean and watch (over a feww days) where it comes from...
t..
Old Oct 30, 2002 | 08:56 PM
frogsr's Avatar
Default Re: v-tec solonoid oil leak? (KAMiN)
there are actually two screens. one on top and one on the side of the vtec solenoid. actually, gasket/screen/filter pieces.
Old Oct 30, 2002 | 09:00 PM
JICsube's Avatar
Default Re: v-tec solonoid oil leak? (frogsr)
i went and checked, it is my cam seal and also my vtec solonoid.. 2 leaks DAH! how do i fix the cam seal? thanks for all the help guys!
Old Oct 30, 2002 | 09:40 PM
Malice's Avatar
New User
ur gonna have to take out the exhaust cam to get to the cam seal. once the cam s off u can just pop of the seal and replace
Old Oct 30, 2002 | 10:01 PM
mugenracer's Avatar
I've had 5 hondas with Bseries vtec engines and had solenoid leaks on 3 of them!, Damn $15 for that seal, i only paid around $2-3 if i remember correctly!
Old Oct 30, 2002 | 11:36 PM
AtomiK_EK's Avatar
Yep, you have to remove your exhaust camshaft in order to replace the cam seal. You can even get an aftermarket one which is made of aluminum or some other kind of metal if you want. Don't forget to add a small amount of liquid gasket to make sure it doesn't leak again.
black94lude
Nov 10, 2009 09:11 AM
d16vteceg
Jul 8, 2006 09:36 PM
b18c inside
Jan 16, 2006 12:05 PM
hybrid1990crx
Aug 12, 2005 10:41 AM
4dohs4mohoes
Aug 2, 2003 04:37 PM
