d16z6 block with d15b7 head? Can this work?
ive dont the search box thing and im not finding the anwsers i need i got a 92 eg hatch with a d15b7 in it the bottom end is locked up but the head is good can i use a d16z6 block with the d15b7 head ? if so what do i need to get to make this happen or is it a stright bolt up ? thanks for any help
From the 88-91 FAQ
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
Not all those steps will apply but it'll get you where you need to be.
Why does this write up not work?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
It actually does if you're able to think it through backwards which is what I did a few years ago. It's a backwards/reverse mini-me I guess...
one correction, you don't need the the z6 intake manifold. all of the b7 accessory parts work on the z6, and vice versa. however, you will need a b7 distributor. the z6 distributor is the oddball of the d series family and has different mounting tabs.
https://honda-tech.com/forums/showthread.php?t=2754616
This one has pics. Rumor has it that the A6 and B7 heads are the same.
I don't see the Z6 IM improving the B7 head without tuning but I definitely could be mistaken.
Do you know what the difference is between the cams? I assumed the a6 is more aggressive but I could be wrong, I honestly have no clue I haven't ever seen them measured just that alot of people seem to like the a6 better.
and the z6 intake manifold doesn't even fit well, the head really should be ported to match. The improvement isn't great until its tuned and the cam is upgraded to take better advantage of the more airflow, thats what IV seen on d15beast7 builds. But it isn't really so much like the v6 forum I was on where people would dyno tune literally every single different little bolt on or mod they would do, in a group attempt to figure out how to push the most power out of the j series.
The cams have been measured though it would take a bit of searching to find the results. I believe "Tyson" or "jlicrx" maybe even "Mista Bone" (I forget, it was ages ago) may have been behind that effort several years ago, maybe a decade or more.
Back on topic...
Back on topic...
CivicHP
13
Jun 6, 2005 04:30 AM
