D15b7 with d16z6 head vtec won't work
I have all the wires hooked up how they're supposed to be to the ecu (using a diagram I found on here) I have a p28 ecu. No check engine light. I don't know if I have a knock sensor or not cause I haven't looked to see if there's one back there but I figure if something was wrong with the knock sensor the check engine light would be on. I'm not sure if there was something on there to bypass the knock sensor completely or what. Cause if that's the case then maybe my solenoid is just bad? Or my oil pressure switch. I just don't see what I'm missing, as long as I've had the car I've never been able to get vtec to work. A lot of guys on here seem to really know what they're talking about so I'd really appreciate any input on this situation.
How do you know it isn't working? You aren't throwing any codes. Are you able to take it to redline? Are you positive you wired it properly?
I used this picture I found on here to help me out. I wired the oil pressure sensor and the solenoid to the plugs it says to. And I grounded it. But yeah I can redline it and nothing happens. My check engine light comes on every now and then for a minute or two but it's always when I'm driving. I can't get it to come on at the house so I can pull the codes. I'm not sure if that has anything to do with the vtec though.
chinoslines
Jul 5, 2010 03:59 PM
1SickEG
Jan 17, 2007 03:05 PM
