gsr swapped ek axle issue
Old Jun 5, 2014 | 03:48 PM
racing_reject_001's Avatar
Icon2 gsr swapped ek axle issue
swapped in a gsr into my 00 civic hatch about a year ago, reacently did an oil change and noticed my axle was leaking, saw that the boot was leaking and it looks like the boot rubbed through itself. Now im not incredibly low and before i swapped it i never had this issue. I am wondering what is the negitive camber causing this? and if not how can i fix it? And yes i used pepboy axles.
Old Jun 5, 2014 | 04:06 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: gsr swapped ek axle issue
Camber doesn't cause axle issues. Shitty axles cause axle issues. The fix is easy - replace the axle.
Old Jun 5, 2014 | 04:49 PM
carlos8's Avatar
Replace the axle.... Lifetime warranty is your friend.
Old Jun 6, 2014 | 02:12 AM
well i figured that was the answer thanks guys now should i just go with actual honda or an upgraded one??
Old Jun 6, 2014 | 06:39 AM
tony_2018's Avatar
Fish Twig
You can figure that one out on your own, your car.
Old Jun 6, 2014 | 06:45 AM
visiblystealthy's Avatar
Buy oem honda, upgrade if you choose to. Otherwise, if you're going to go to a parts store, make sure you get the "new" axle with lifetime warranty. Anything else will only cause you problems unless you're part of the lucky few.
Old Jun 6, 2014 | 08:42 AM
ok thanks again guys i was shocked because the passanger side hasnt split yet and a couple guys at work said it was because oh my ride height and the cheap pepboys axles
Old Jun 6, 2014 | 10:56 AM
NVturbo's Avatar
O.G. triple O.G.
Unless the car is making something near 600HP, I would get one from AutoZone or a factory Honda one. No need to go spending crazy money on such things.
Old Jun 10, 2014 | 08:18 AM
Well thatll never happen haha but yea im already running a pepboys axle and that split so i figured it was either bad quality or due to the geometry of my suspension
Old Jun 10, 2014 | 08:21 AM
NVturbo's Avatar
O.G. triple O.G.
All my previous swapped Hondas....not one broken axle.
PhiLLyMYdiLLy
Mar 16, 2017 09:38 AM
Stonage07
17
Feb 11, 2017 05:11 AM
lerks909
Jul 25, 2014 10:25 AM
taimysho0
Jul 8, 2009 01:29 PM
eghatchproject
Apr 5, 2004 03:25 AM
