Fuel/spark/air/timed but no start
Old Jun 1, 2014 | 10:11 AM
steve<3'sboost's Avatar
Default Fuel/spark/air/timed but no start
Any suggestions? Ecu is good, all grounds and wiring connected. And sensors that could be bad that will make it not fire even with fuel spark and air?
Old Jun 1, 2014 | 10:22 AM
myEKsedan's Avatar
Default Re: Fuel/spark/air/timed but no start
Originally Posted by steve<3'sboost
...sensors that could be bad that will make it not fire even with fuel spark and air?
I dont get it...you say it has fuel spark and air but not firing with fuel spark and air. Confused?
Anyways, year/make/model? Stock? Mechanical timing spot on?
Old Jun 1, 2014 | 10:40 AM
You say you're confused.. I'm beyond lost lol timing is dead on, has fuel spark and air and still will not fire. Only crank and backfire from loading up and sparking and it's a '99 jdm b18c itr swapped ek hatch
Old Jun 1, 2014 | 10:48 AM
myEKsedan's Avatar
spark plug wires in correct order? how have you checked that its getting fuel? and any codes or check engine light?
Old Jun 1, 2014 | 12:23 PM
Wires are correct and pulled the rail off and injectors are firing correctly and in order. The pump is still priming and I still have fuel pressure and everything. Everything mechanically seems good. New distributor too
Old Jun 1, 2014 | 02:57 PM
sikefcrx89's Avatar
Loved
Firing order,distributor is 180* out or timing.
sikefcrx89's Avatar
Loved
Also check/clean your thermostat ground
famdakam
Engine Management and Tuning
Feb 11, 2017 01:21 AM
Boost_em1_
Mar 17, 2014 01:04 PM
tuquikgsr
Dec 18, 2008 09:40 PM
alupso
12
Oct 3, 2008 07:41 PM
Eg4-TuRbO
Jul 30, 2004 11:48 PM
