Retarding timing
Old Oct 30, 2002 | 03:11 PM
Fatty_1775's Avatar
Default Retarding timing
How much should you retard the timing on a B16 with a stage 2 revhard kit? Is two degrees enough? Thanks.
Old Oct 30, 2002 | 03:36 PM
Kataku2K3's Avatar
Default Re: Retarding timing (import_racer)
What PSI/Bar are you running??? Do you have a boost controller or just a preset wastegate.. Tell us a little more info.
Old Nov 13, 2002 | 03:53 PM
Fatty_1775's Avatar
Default Re: Retarding timing (JDMspecEG6)
I have a stage 2 revhard on a second gen jdm b16, shows that i am boosting 9 psi
Old Nov 13, 2002 | 04:12 PM
Kataku2K3's Avatar
Back it down a few degrees then see how far you can bring it up without detonating.. On 9 PSI you probably wanna go back a little more than 2 degrees... Latez
Old Nov 13, 2002 | 04:47 PM
Evs-One's Avatar
Solbros Owns Me
you need to do more than just retard your timing if you want to achieve full potential out of the engine/turbo. But for now, retarding your timing will deffinately help with detonation
Old Nov 13, 2002 | 04:51 PM
RedHatch's Avatar
Default Re: Retarding timing (Emerica)
Your timing isnt the only thing that's retarded.
Old Nov 13, 2002 | 05:17 PM
Fatty_1775's Avatar
Default Re: Retarding timing (RedHatch)
The person who put the turbo in retarded the timing by 10 degrees he said.
Old Nov 13, 2002 | 05:39 PM
Kataku2K3's Avatar
10 degrees from stock??? So your timing is at like 6 degrees?? What else are you running for fuel and ECU??
[Modified by JDMspecEG6, 6:39 PM 11/13/2002]
Old Nov 13, 2002 | 06:08 PM
Fatty_1775's Avatar
Nothing, I have a vortech fmu that came with the kit. Any recommendations? Anyone?
Old Nov 13, 2002 | 06:22 PM
Kataku2K3's Avatar
Is your motor internally stock?? My friend ran his B16 in his EK and pulled a 12.7@106 on 7psi... He was just running a Drag kit with stock ECU and VAFC.. Your RevHard kit is a lot better.. hehe
Old Nov 13, 2002 | 06:30 PM
Fatty_1775's Avatar
On stock internals?
Old Nov 13, 2002 | 06:33 PM
Fatty_1775's Avatar
Stock internals? What did he do to his engine? Thanks.
spoolingb20
Apr 26, 2006 10:46 AM
bmm89
Nov 21, 2004 08:17 PM
B_1_8_hatch
Jul 28, 2003 01:33 PM
wrXtian
Mar 25, 2003 03:55 PM
DIRep972
Sep 22, 2002 02:29 PM
