NEED HELP WITH FUEL LINE!
hey guys, so i have a 92 civic hatch. it has a b16A swap. i just recently built the bottom end as i plan on boosting it. I bought a AEM fuel rail which fits perfectly, but the bolt that came with the fuel rail doesn't have a feed hole in it like the OEM bolt, i can't switch them out either because it doesn't fit. its the bolt that connects the fuel filter hose to the rail. My question is; what setup do i need to make this work. first time doing all of this so I'm kind of in the dark and i need some help.
2 options.
1 - cheaper but it works, cut the end of your current fuel line that bolts to the fuel filter, as long as possible to slide a fuel hose over and clamp it on, and the other end of the hose to slide over the fuel rail nipple and clamp.
2- Get an AN fitting for the fuel rail and a hose that have an AN fitting on one end and a banjo on the other
