Rod bearing failure inside (D16Z6)
Old May 24, 2014 | 08:21 AM
joppe's Avatar
Default Rod bearing failure inside (D16Z6)
Eagle rods, acl race bearings, std size, engine is built 2011 and has about 15K miles on it, including drag and circuit racing. 340Whp on E85, 15w-60 ester based race oil (i used redline 10w-40 before but pressure dropped to 45psi at hot)
Worst bearings were on 3rd. one rod bearing and main bearings was ok. Engine was plastigauged at build and clearance was 0.04-0.045mm. Engine had some misfire at high boost, and im wondering can it break bearings like this or is this lubrication problem?
Old May 24, 2014 | 08:50 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Rod bearing failure inside (D16Z6)
Those bearings look like they lost oiling and cooked themselves to death.
Old May 24, 2014 | 09:25 AM
joppe's Avatar
ACL race bearings are kind of black at new? Rods didnt have any discolor.
Old May 24, 2014 | 01:27 PM
1HGEJ2's Avatar
how much rpm did u use? modified oil pump?
Old May 24, 2014 | 03:41 PM
SpokaneSpeed's Avatar
Definitely looks like lack of oil lubrication by looking at the bearings...
What oil pressure were you normally seeing at operating temp @ idle?
Old May 24, 2014 | 04:02 PM
joppe's Avatar
About 20psi. Oil pump is ported, rev limit 7800. Even with this failure it had 15+psi at idle
Old May 24, 2014 | 04:41 PM
DDTECH's Avatar
clearances ?
Old May 24, 2014 | 06:28 PM
TheToaster's Avatar
Knock wore them away and then spun them, once spun, they wear.
Old May 24, 2014 | 10:06 PM
Originally Posted by DDTECH
clearances ?
Read the OP ;-)
Roy Leyva
Engine Machining & Assembly
Jan 26, 2017 06:43 PM
alperx
Jan 10, 2012 06:56 PM
RACEPAK
Sep 18, 2010 06:52 AM
pkolaboy
Jan 9, 2008 08:50 PM
svmnredracr
Aug 2, 2004 06:59 PM
