Quick timing question
Old May 22, 2014 | 07:57 PM
Kid-jdm-teggy's Avatar
Default Quick timing question
Which timing mark is advancing and which is retarding? Standing in front of the car, is the advance mark closer to the firewall and the retard closer to you?
Old May 22, 2014 | 09:23 PM
slowcivic2k's Avatar
Default Re: Quick timing question
On a 351W Ford, rotate the distributor counter-clockwise for advance, opposite for retard.
Old May 23, 2014 | 06:49 AM
What about a Honda? I just want to know which of the three timing marks on the pulley is the advance and which is the retard.
Old May 23, 2014 | 10:27 AM
holmesnmanny's Avatar
in other words since you didnt have the courtesy to post year make and model you're gonna get a generic guess as to what kind of car you have
Old May 23, 2014 | 06:51 PM
I didnt know people talk about Fords on here also. But i dont know if a timing mark will be different on a d series than say b, k, f, j, or h series. I thought they are all the same, just need to know which mark is the retard timing
Old May 23, 2014 | 07:17 PM
I like Honda's, but Ford's make the money.
Old May 26, 2014 | 01:07 AM
your question is really ambiguous however slowcivic already answered it to the best of anyone's ability given your original question
Old May 28, 2014 | 11:31 AM
thesmogman's Avatar
On your 95 acura the timing should be between the two red marks. The two red marks are the + or - two degrees from spec
Old May 28, 2014 | 01:15 PM
raverx3m's Avatar
lol thread fail
10 second google search
http://www.c-speedr.com/howto/timing/timing.php
and by the power of common sense I can deduct that the furthest mark from the TDC mark is the one with more degrees
Old May 28, 2014 | 11:16 PM
series434's Avatar
I think advance is towards the fire wall
Old May 29, 2014 | 03:15 AM
bambam's Avatar
Well if you can picture how an engine runs, and you know the timing belt spins counter clockwise. So if you rotate the cam gears clockwise, the valves will be opening sooner i.e. "advanced".
So, in any engine, advancing cam timing is obtained by rotating the cam gears in the opposite direction of engine rotation.
GencivicIII
Dec 10, 2002 04:16 AM
C4wrx
Feb 6, 2002 07:08 AM
fso_BamBam
Aug 21, 2001 01:50 PM
