Wipers Wiring Harness
Old May 19, 2014 | 03:02 PM
honda_lx's Avatar
Default Wipers Wiring Harness
So I'm troubleshooting a problem with the wipers running continuously and not parking. I opened up the wiper and jiggle the wire and I can press it and activate the wipers. Smoke came out from the steering column...
Problem is the wiring harness is down in there. Please tell me I don't have to take off the dash to find this open. Also, I think it's the ground wire. Can anyone confirm which wire after the 6 pin connector is the ground? I think it's the green wire.
Thanks~
Old May 19, 2014 | 04:08 PM
Lost Again's Avatar
Default Re: Wipers Wiring Harness
So is this a 90 or an '02 Accord.....and some of the newer ones it matters what trim the car is.
What testing procedures are you following?
Without much to go on here. I'll guess, replace nothing on a guees, that the wiper switch is toast. Now that there has been "smoke", there might be some wires that are toast as well.
Old May 20, 2014 | 10:45 AM
honda_lx's Avatar
Default Re: Wipers Wiring Harness -- Wipers Run Contionously
I tested wiper module and it has continuity in all the right places. Wiper switch is good.
Is it possible to completely remove the wiring harness to the wiper module (7 pin connector). If so, can someone tell me where the other end connects to?
When I move the steering wheel up the wipers start running (I imagine it's short to ground?) when I push the steering wheel back down the wipers stop immediately and don't park. I suppose it could also be the Ignition Control Unit, since the wipers don't park.
Thanks~
creativename
Nov 27, 2017 12:52 PM
ZCHondaCRX91
Nov 15, 2011 01:37 PM
GReddy_Civic
Oct 18, 2009 10:21 AM
pmendoza
Mar 31, 2006 04:21 AM
Civichatch972
Audio / Security / Video
Nov 19, 2003 08:29 AM
