cruise control in a '90 crx
Old May 15, 2014 | 09:36 PM
90redSIguy's Avatar
Default cruise control in a '90 crx
hello everyone,
im adding the cruise control in my car and i already have the cc stick inside and i just found theres some wires which i think was used for the cruise control (no pics right now), my question is this: after i get the servo do i need the intake w/the little wheels for the cruise off of say an accord that has cruise control or can i just grab the little wheels off the intake and install them on my intake (which isnt the carburated model)?
Old May 17, 2014 | 10:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: cruise control in a '90 crx
What MM&Y of car is the CC off of? 94
Old May 17, 2014 | 10:37 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
did these cars come with cruise as an option? the closest thing to you would be the third generation accord, 86-89 they use a specific set of pedals with an arm that the cable for the vaccume solenoid attaches to, you will need the special brake switch, with the two circuits, and the clutch switch if you dont have one, I'm sure the accord brake switch will screw right in, one of the critical pieces, is the speed pulser in the speedometer head, this tells the cruise how fast the car is actually moving. If these cars came with an optional cruise control, I'm sure it's very close to the accord setup. the Accord cruise module can't use a VSS, as a VSS output is 5 volts, and the module is designed for a grounding pulse, not voltage. this is a lot more complicated then you think it is, I did this for my 86 Accord, but never finished it, as I decided I didnt want to have cruise
sw2513
Aug 15, 2017 01:37 AM
kain9i6
Dec 17, 2011 05:01 PM
aubreylorraine
Mar 7, 2010 02:15 PM
commoncents100
Mar 4, 2007 04:24 PM
