Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2005 Honda Accord EX-L V6 - Cruise Control Assembly - Wrong one?
Old 12-23-2010, 05:36 PM
kain9i6's Avatar
Icon2 2005 Honda Accord EX-L V6 - Cruise Control Assembly - Wrong one?
I have a 2005 Honda Accord EX-L V6 and currently my cruise control switch was broken. I would press it, the cruise control light would turn on, but when I release the switch, it would go off. Something inside the switch iteself was broken as the switch wouldn't stay engaged.
I recently ordered a Cruise Conrol Assembly to replace it, but when I pull the broken assembly out, noticed that the connections that go into the assembly are quite different. The picture below shows what I believed the assembly and wires should look like. One connector with 5 connection points that the new assembly should snap into.. however, the old one has two separate connectors, one with three connection points and the other with 4, making a total of 5 wires and two connectors. I'm not sure if I got the wrong one or if the previous owner had some work done and they replaced the switch with a different one.. I'm at a loss. Now I have NO cruise control as when disconnecting the old switch, the connectors came apart.
Would anyone happen to know (by color) where each wire is supposed to go so maybe i can just buy a like connector and place the wires myself. Also, what each of the 7 wires are for?
Any help would be appreciated as I'm pulling my hair out as I thought this would be an easy replace job.
Thanks!
Old 12-23-2010, 05:56 PM
redbull-1's Avatar
Default Re: 2005 Honda Accord EX-L V6 - Cruise Control Assembly - Wrong one?
You probably bought the wrong part. There are three different part numbers depending on whether you have audio remote or not, and navigation or not.
This is a part which should been ordered based on the VIN.
Without Audio Remote Honda part number: 35880-SDN-A02ZA
With Audio Remote (w/o navigation system) 35880-SDP-A01ZA
With Audio Remote (with navigation system) 35880-SDP-A11ZA
Old 12-24-2010, 05:22 PM
Kev2010's Avatar
You probably bought the wrong part. Find out what model you have, and match your model to the part.
Old 12-17-2011, 05:01 PM
05acse's Avatar
Icon2 Re: 2005 Honda Accord EX-L V6 - Cruise Control Assembly - Wrong one?
I have a 2005 Honda Accord Coupe LX-SE. The local Honda Parts outlet tells me I need 35880-SDN-A02ZA indeed. Had gotten the same wrong part as original poster, too. Guess I deserved that, ordering online before talking to Honda Parts. So, I can fix that now, but the real problem is, the two plastic plugs are solidly stuck onto the failed switch assembly. I tried to use needle nose pliers to nudge them off, but they are not budging one bit. Is there a trick to getting these off? Obviously, there is no point in buying the correct part, if I cannot get the pugs off the failed part. Thanks.
mikeburciaga
03-18-2013 03:37 PM
dewayne33us
01-31-2010 10:19 AM
amb4081
05-12-2006 10:18 AM
Quick Reply: 2005 Honda Accord EX-L V6 - Cruise Control Assembly - Wrong one?
