Cooling Fan Stopped Running
Old May 14, 2014 | 04:52 PM
BudWheel's Avatar
Default Cooling Fan Stopped Running
Iv been trying to get my CEL from flashing and finally did YAY! But now my cooling fan stopping running. At first it was running all the time when I turned the key. The fan isn't bad but I'm not getting power to it. I guess Ill start with the sensor that turns it on in the first place. That would be the one at the thermostat right? If so, if I was to unplug it and put a paper clip in it will it start running the fan if everything is hooked up correctly? It probably wont work since someone rigged it up to run all the time. Does anyone know of a good wiring schematic for the fan? Well hope to fix this soon and thanks to anyone that helps me
Old May 14, 2014 | 05:03 PM
turtlegrip's Avatar
Default Re: Cooling Fan Stopped Running
service manual will have schematic if you can get your hands on one. Normally shorting the switch plug will make it run constant. That would tell you if the sensor was bad. There is likely a problem with whatever wiring someone did to make it constant (a wire and electrical tape on the sensor plug would have been easier for them). Or maybe your fan burned out from running all the time.
Try shorting the plug and then try undoing whatever wiring was done along with figuring out why they felt the need to do that.
Old May 14, 2014 | 05:15 PM
BudWheel's Avatar
The fan still works. I plugged it up with another connector I had to the battery and it ran just fine. As for service manuals I was trying to find a factory one I can download but have no luck. Iv found some that are $50 plus but Im not paying that much. The Haynes manuals are a last resort since they suck so badly these days. Still wanted to know if the sensor at the thermostat was the one that started it and if I paper clipped it is it supposed to start? Ill try it in the morning since I don't have to work tomorrow.
Old May 14, 2014 | 05:18 PM
dizzyroc88's Avatar
see the post just above
Old May 14, 2014 | 05:25 PM
BudWheel's Avatar
Yeah I spoke too soon lol. You wouldnt happened to know where to get one for a 93 del sol would yeah?
Old May 14, 2014 | 05:31 PM
grumblemarc's Avatar
The Grumpiest
Google dammit!
If your fan is rigged to run all the time you have other **** to fix. Get the car back to where it's supposed to be. Usually people do lazy **** like that when they don't want to replace the thermostat or some other faulty sensor.
Old May 14, 2014 | 05:38 PM
BudWheel's Avatar
All I wanted was a yes or no grumpples.
Old May 14, 2014 | 05:42 PM
The Grumpiest
Yeah. And now you got people (that should know better) posting links to illegal downloads which is strictly against the TOS.
Old May 14, 2014 | 05:45 PM
dizzyroc88's Avatar
-_-
Old May 14, 2014 | 05:46 PM
The Grumpiest
Reported.
Old May 14, 2014 | 05:48 PM
dizzyroc88's Avatar
get a life
Old May 14, 2014 | 05:49 PM
The Grumpiest
Get a clue.
And OP. 117,000 Google search results using the keywords "93 del sol fan wiring diagram".
https://www.google.com/search?q=93+d...m=122&ie=UTF-8
Took all of 10 seconds.
Old May 14, 2014 | 05:58 PM
BudWheel's Avatar
You eat some bad kibble today? Didn't have the caned tuna? Calm down no need to be so rude. I needed help with something and there is so much mumbo jumbo on the web I cant make heads or tails about so I thought I come here for some help. So chill out. Don't like my post ignore it and go somewhere else. Since you so called reported this Id like to say sorry admins for this ridiculous post but there is no needs for people being butts when someone has a question.
Old May 14, 2014 | 05:59 PM
The Grumpiest
People need to stop being so lazy. What I just did you could have done for yourself. Mumbo jumbo? You needed a diagram. A picture. A Google image search would have found that with no text for you to have to read. Give me a break with the excuses. You didn't search. Try it sometime.
Old May 14, 2014 | 06:15 PM
BudWheel's Avatar
Yup and 90% of it is junk to me I see more Mercedes images then Honda.
Old May 14, 2014 | 06:19 PM
The Grumpiest
Nevermind. I found your diagram. But since you're all about name calling you can find it yourself.
Old May 14, 2014 | 06:57 PM
Slacker93eg's Avatar
10 Year Member
I understand the concept of search, which is how I found this post, but if people didn't ask questions this forum wouldn't need to exist, nor would there be threads to search for. Is there a thread limit or something? Calm down.
Old May 14, 2014 | 08:06 PM
turtlegrip's Avatar
I do hate doing more research then the OP for them, but "Slacker" (lol) has a good point imo. Either way, if you cant figure it out even after the google link to the images I dont know how you plan on making sense of an electrical diagram, since its far more confusing than image names....
anyway the engine coolant temperature switch is the same one i was talking about in my first post, on the t-stat housing.
Follow this, I only read the first two posts but it will probably lead to you fixing your problem. It was the first result after searching "honda engine coolant temperature switch".
Old May 14, 2014 | 08:35 PM
BudWheel's Avatar
Sorry for the name calling but I didn't like how you cussed me out first post
Old May 14, 2014 | 08:36 PM
BudWheel's Avatar
Thanks Turtle that post helped me out a lot.
Old May 15, 2014 | 02:19 AM
HondaPartsHero's Avatar
Technical Hero
Always put your year/make/model/trim in your first post to help us know what you have but this should be similar
zx92027xz
17
Sep 29, 2024 09:55 AM
jdragon1974
May 20, 2010 08:24 AM
FONK
Jan 12, 2006 03:03 PM
FONK
Jan 11, 2006 08:48 PM
Suck my DX
Jun 21, 2005 07:21 AM
