B21A1 Engine Swap
Old Oct 30, 2002 | 10:54 AM
gixer00's Avatar
Default B21A1 Engine Swap
I was wondering if anyone out there ever took a motor out of a 90 Prelude. becouse i want to know if there is a engine mount kit available for the 97 Del Sol and also what kind of axels are suggested for this swap. and does anyone know if a GSR trans would bolt up or not.
thanks 4life
Old Oct 30, 2002 | 10:57 AM
BackSideSA's Avatar
Default Re: B21A1 Engine Swap (chidelsol)
its not worth it....i say you should go d15b7 non vtec
Old Oct 30, 2002 | 11:03 AM
Doctor CorteZ's Avatar
they made that motor for less than 3 years for a reason.
WORST rod/stroke ever........... plus I'm quite sure that is does not share anything with the new B-series.
Old Oct 30, 2002 | 11:07 AM
stevecockrill's Avatar
Nope, that motor sucks.
Plus, you can't (legally) put an older engine in a newer chassis.......good luck getting inspection if you do.
Go with a B or H series swap. If $$ is an issue, go SOHC VTEC for now, they can be picked up for a song. What model is your del Sol? You have a 2 in 3 chance it already has a VTEC engine!!
Steve
Old Oct 30, 2002 | 11:08 AM
thinkbrianthink bu's Avatar
Default Re: B21A1 Engine Swap (Doctor CorteZ)
like the doctor just said...
that is the absolute worst engine honda ever made.
no b.s.
I had to swap a head on one of those one time and i would rather chew glass and rusty nails before ever even being in the same garage as that motor again.
Old Oct 30, 2002 | 11:11 AM
Default Re: B21A1 Engine Swap (thinkbrianthink)
Nevermind....me stupid
[Modified by stevecockrill, 8:11 PM 10/30/2002]
Old Nov 4, 2002 | 10:30 PM
mclarenhonda's Avatar
whys the b21a1 a bad engine??
Old Nov 4, 2002 | 11:07 PM
The_Head's Avatar
Default Re: B21A1 Engine Swap (mclarenhonda)
I dont know if it's a bad motor, I still see quite a few 88-91 ludes running around.
I assumed it was because of the really long stroke of the motor. But I looked it up:
Bore= ~94 mm, Stroke= ~79mm
Old Nov 4, 2002 | 11:10 PM
RR98DX's Avatar
Default Re: B21A1 Engine Swap (xThexHeadx)
But I looked it up:
um. no. try 83 mm x 95 mm.
Old Nov 4, 2002 | 11:20 PM
The_Head's Avatar
Default Re: B21A1 Engine Swap (RR98DX)
I stand corrected. for using MSN carpoint as a reference
lusciouslett12
Mar 17, 2015 12:32 PM
DelSol63116
Mar 17, 2014 05:58 AM
Matt Kotyk
Jan 1, 2013 12:35 PM
alexbyoung
46
Dec 27, 2002 09:12 PM
