Custom length rod/heim joints?
Old May 6, 2014 | 06:03 AM
Tippyman's Avatar
Default Custom length rod/heim joints?
I am making some custom engine mounts and need some heim joints on adjustable length rod. Like the hollow threaded rod/jam nut setup you see on most Honda traction bar setups.
Basically I want to measure the distance between my mounting point on the engine and the subframe, and order a rod in that length. Obviously adjustable +/- .5" or so.
Anyone know where to source these?
Old May 6, 2014 | 07:02 AM
Pro-SeriesFab's Avatar
Default Re: Custom length rod/heim joints?
They are known as tube ends. There's probably a ton of racing companies that sell them as they are a basic part and can be knocked out on a CNC lathe in no time.
FK makes some of the finest rod ends but, like anything, I'm sure you can find cheaper.
http://www.fkrodends.com/WELD44.html
Typically with a custom bar, you order a 6' stick of the size tubing you want to use and just cut to length when you have the rod ends and tube ends in place.
Welding is required obviously . . .
Old May 6, 2014 | 09:42 AM
Tippyman's Avatar
I have welding and minor fab experience so that isn't an issue, but I wanted something adjustable with jam-nuts like a traction bar. That way I can crank a little proload into it before tightening up to ensure no wiggling under load takes place.
Old May 6, 2014 | 11:27 AM
HellaFab's Avatar
the link he provided is what you want. the assembly would be a rod end, nut and then a weldable insert.
Then you just get a tube to weld either of the threaded weld inserts to.
if you want it adjustable without removing one end, you will need a right and left hand threaded rod end for each rod.
Old May 6, 2014 | 07:35 PM
Tippyman's Avatar
Ooohhh... Got it now, thanks for the kick-start to my brain. Off to the drawing board...
Old May 6, 2014 | 08:39 PM
turbohatch96y7's Avatar
watcha makin?
Any rough pics?
Old May 7, 2014 | 03:14 AM
Tippyman's Avatar
Originally Posted by turbohatch96y7
watcha makin?
Any rough pics?
I am trying to eliminate any possibility of wheelhop on my civic, so I'm making some solid bars that connect the engine to the front and rear cross-members. Trying to help out the existing mounts, basically.
Old May 7, 2014 | 06:25 AM
.adam.'s Avatar
http://www.summitracing.com/oh/searc...rder=Ascending
Old May 7, 2014 | 07:04 PM
Tippyman's Avatar
Bingo, even easier. Order a l.h. threaded end, a r.h. threaded end, couple of jam-nuts, and you're good to go.
Thanks!
Old May 7, 2014 | 08:49 PM
abnaasefmb's Avatar
http://secure.chassisshop.com/categories/5939/
Old May 8, 2014 | 02:26 PM
.adam.'s Avatar
no prob, i live 5 minutes from summit and all of their sales guys suck so ive become quite the summit racing search engine over the years.....
skipbudlong
31
May 6, 2010 10:21 AM
Fred Allen Burge
Welding / Fabrication
12
Apr 4, 2006 10:23 PM
Knestis
28
Feb 16, 2006 06:47 PM
2point2
Jun 29, 2004 02:29 PM
boosted3g
Jan 15, 2003 04:48 PM
