1994 del sol brake light
Old Apr 26, 2014 | 06:42 AM
Will Scott's Avatar
Default 1994 del sol brake light
I have a 1994 honda civic del sol. The brake light in the dash that tells you the hand brake is on has stopped going off so now whenever I drive even after I take the brake off the light still stays on. I was wondering what I had to do to fix this.
Old Apr 26, 2014 | 11:35 AM
holmesnmanny's Avatar
check your brake fluid level
Old Apr 29, 2014 | 05:23 PM
fcm's Avatar
fcm
Old Fart
Default Re: 1994 del sol brake light
Ditto the above^^^ if level good check the brake fluid level switch.
Question, does the light dim a little when the Ebrake is off, if so the problem is most likely the brake fluid level or the BFL switch. 94
97delslo
Jul 29, 2015 12:59 PM
[Rush]
21
Apr 12, 2010 08:18 PM
jdm.coupe3234
15
Jan 22, 2010 12:57 PM
Blk_Lude98
Oct 20, 2006 07:27 AM
projecteg2
May 25, 2004 06:21 PM
