Removing IACV on Crome and Hondata
Old Apr 24, 2014 | 03:33 AM
GT500FTW's Avatar
Default Removing IACV on Crome and Hondata
Hey guys
I've blocked off my IACV and FITV on my car for cooler intake temps and to fix an idle problem.
My car is getting its first map next month. (B16A2 OBD1 with Apexi turbo kit and other mods)
My tuner is either going to use Crome or Hondata (s200) to map the car (depending on my setup he will decide on the day)
I want to remove the IACV program from the ECU so when I unplug the IACV, there will be no CEL and no erratic idle.
Just in case he's never been asked to do this before, how do I instruct him to do this for Hondata and for Crome? - Is it quite easy?
Thanks
Old Apr 27, 2014 | 08:59 AM
VegasInvasion's Avatar
I'm Huge In Japan
Default Re: Removing IACV on Crome and Hondata
Your tuner isn't going to use S200. I doubt he has access to or knows how to use RE4.
Also, you're misguided if you think you won't have an erratic idle without an IACV. Quite the opposite. You clearly have a vacuum leak somewhere, and if your tuner is competent he'll tell you the same thing and won't tune it until you fix the leak. If he doesn't know how to disable the IACV then that's not a person you trust to tune your car, period.
Old Apr 27, 2014 | 03:05 PM
GT500FTW's Avatar
Thanks for your input.
I have blanked the iacv and fitv with no issues now. My idle is perfect.
I definitely don't have a vacuum leak. Period.
How do you know my tuner won't use s200?
Thank you for not answering my question.
Old Apr 29, 2014 | 06:54 PM
I'm Huge In Japan
Noob, if your tuner had access to RE4 to burn an S200 chip you wouldn't need to ask this question for him. It's a basic feature in all rom editors - even the obsolete ones.
I've tuned probably over a thousand Hondas; regardless if you like my answer, nobody else has responded because I've already given you the correct advice.
Old Apr 29, 2014 | 07:58 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
He is right, there isn't much to add really. You need to ask your tuner. If he doesn't know then find someone who does. This of course assumes you don't have the tools yourself of course.
Old Apr 30, 2014 | 12:58 AM
GT500FTW's Avatar
You're right, I am a N00b when it comes to mapping, and that's why i asked on here.
If I had tuned thousands of Hondas then i wouldn't need to post then.....I thought that was pretty obvious.
My tuner has the ability to tune with both Crome and Hondata. As i hinted in my post, I was asking on here before asking my tuner if he could do it.
I wanted to know if it was possible to do it as a knowlege building exercise, so that when i ask him to remove it, I at least know a little bit about it.
I'm sorry to disagree, but your first response didn't include the correct advice.
1 You assumed that my tuner can't use Hondata - Wrong
2 You assumed i had a vacuum leak - Wrong
Your second response gave me some of the info i asked for when you said "It's a basic feature in all rom editors - even the obsolete ones."
Thanks for the information
eg:R
May 29, 2006 01:51 AM
brokenojoke
Mar 23, 2005 07:51 AM
Kwuaymaikrup
Sep 16, 2004 02:20 AM
DUALSTAGE
May 3, 2002 02:41 PM
