Hasport Mounts
Old Apr 14, 2014 | 05:42 PM
Uljima's Avatar
Default Hasport Mounts
Recently just ordered the Hasport motor mounts for my civic 2000 (ek) w/ a b18b1 swap. On the driver side, the driver bracket one off the screws snapped, can i replace the screw with any other screws or does it have 2 be one off those pointy ones?
http://i1089.photobucket.com/albums/...ema/photo1.jpg
Basically my question is simple, will i need to get the pointy bolts or can i just replace it with any other bolt that will fit?
update- i have done extensive research over the internet for the pass week, people are saying that I will be needed to change my driver side post mounts to a 99 civic si, and that i need to change my rear transmission bracket to a 99 civic si ( the one that looks like an L or T). Why do I have to change the post mounts, and the rear transmission bracket when they look like they will just bolt straight on?
http://www.jhpusa.com/store/pc/viewP...?idproduct=537
I bought the 3 bolt one since my car is a 3 bolt, for the driver side it looks pretty easy, all you need too do is bolt it in.. the hasport brack example- http://i1089.photobucket.com/albums/.../engine2-1.jpg
as you can see in red, all i need too do is bolt it in, and line it up with the b18b1 post mounts, and put in some bolts and i am rdy 2 go.
I dont understand why everyone is telling me why i need a rear transmission bracket from a 99civic, and a driver side post mounts from a 99 civic?
Another question is it safe to use other bolts rather then the pointy ones?
Old Apr 15, 2014 | 10:09 AM
Hasport's Avatar
Default Re: Hasport Mounts
is the engine already in the car?
if you have not changed the block bracket on the timing side of your b18b1 then the EKSTK-3bolt kit you ordered will work just fine
you will need to use a 99-00 civic si "T" bracket for the rear as the integra one will not work properly
you can use other bolts rather than the 'pointy' ones
slice636
May 6, 2009 12:44 PM
djsire
Aug 1, 2008 01:57 PM
562daybid
14
Mar 19, 2008 12:24 PM
SPD DMN
Sep 20, 2006 01:50 PM
CaptivaBlue
Jul 15, 2005 12:37 AM
