ekstk hasport mounts help!!
* B A N N E D *
I have a jdm sir-g or b18c and I bought along with it hasport mounts ekstk which means ek stock mount replacements. I have a 97 civic hatch.. I also bought the 99 civic si rear bracket. Okay I figured out the eklh left hand mounts which means you have to buy a 99 civic si bracket for it to work and you also need the 99 civic si rear bracket for the hasport egrr rear right mounts to work. But now I need to know...
How does the ekrh hand mounts work? I have pictures..
what do I have to do or get to make these mounts fit??? its right above the tranny.. and the mounts that you see already on there (black ones) are the stock mounts.. I know I have to take them off but im just showing you guys where the hasports are suppose to go
Modified by 562daybid at 10:45 PM 3/16/2008
Modified by 562daybid at 10:57 PM 3/16/2008
Modified by 562daybid at 10:58 PM 3/16/2008
Modified by 562daybid at 11:53 PM 3/16/2008
Modified by 562daybid at 11:55 PM 3/16/2008
Re: ekstk hasport mounts help!! (562daybid)
b18c has two studs and one hole on the driver side engine bracket. and on your ek hasport mount, i think there are only two holes because b16a engine only has
2 studs with no hole on the driver side engine bracket. so u can either swap out the driver side engine bracket with a 94 and up del sol vtec model or 99-00 civic si civic. the pic shown below is my hasport engine mount before i installed them.
let me know if i am wrong
* B A N N E D *
Re: ekstk hasport mounts help!! (crazyguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">b18c has two studs and one hole on the driver side engine bracket. and on your ek hasport mount, i think there are only two holes because b16a engine only has
oh but those are for eg or integra mounts... mines an ek.. uhmm but question about the right hand mounts.. my ek are different than yours.. what do I need in order for it to work for my tranny? you can see what im talkin about with the mount im holding up above..
* B A N N E D *
it doesn't matter if your ek is rhd, the mounts are the same
EKSTK is what you need if you have an offset 2post left side mount
* B A N N E D *
Re: ekstk hasport mounts help!! (n1_egsex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by n1_egsex »</TD></TR><TR><TD CLASS="quote">it doesn't matter if your ek is rhd, the mounts are the same
EKSTK is what you need if you have an offset 2post left side mount</TD></TR></TABLE>
what??? thas not what im saying.. I dont have a RHD.. where are u gettin that from? I have ekstk mounts that why my main title for this post is "ekstk hasport mounts help"
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 562daybid »</TD></TR><TR><TD CLASS="quote">
what??? thas not what im saying.. I dont have a RHD.. where are u gettin that from? I have ekstk mounts that why my main title for this post is "ekstk hasport mounts help" </TD></TR></TABLE>
maybe i mis-read
but in this pic
you got a cable tranny mount, not hydro
maybe i mis-read
but in this pic
* B A N N E D *
maybe i mis-read
but in this pic
you got a cable tranny mount, not hydro</TD></TR></TABLE>
that doesnt make sense.. you mean the hasport im holding is a cable tranny mount? because its ekstk which means it replaces any b or d series motor and it being ek 96-00 means its gonna be hydro regardless.. what im askin is what I need in order for the ekrh mount to work with the picture ur lookin at.. because it doesnt bolt up the same as the b18c stock mounts..
maybe i mis-read
but in this pic
* B A N N E D *
Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">that mount doesnt go there its actually a bracket and the mount bolts to the frame of the car NOT the tranny..#6 is what actually bolts to the tranny
oh I see.. so I need number 6??? can I use the one thats on my stock motor (d16y7) or do I have to get it off a 99 civic si just like I had to get for the left hand mounts and rear right bracket??
H-T Premium Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">the #6 is the same for d series and b series..take ur hasport pass. side mount and try boltin that up to ur pass side engine bay, it should fit</TD></TR></TABLE>
The Hasport mount does bolt to the frame rail in the engine bay and #6 bolts to the transmission.
* B A N N E D *
Re: ekstk hasport mounts help!! (Hasport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hasport »</TD></TR><TR><TD CLASS="quote">
The Hasport mount does bolt to the frame rail in the engine bay and #6 bolts to the transmission.</TD></TR></TABLE>
I know I have #6 on my single cam already. Can I use #6 from my single cam and bolt it up to my b18c transmission and then use the hasport mount and bolt it up to #6??
H-T Premium Sponsor
I know I have #6 on my single cam already. Can I use #6 from my single cam and bolt it up to my b18c transmission and then use the hasport mount and bolt it up to #6??</TD></TR></TABLE>
yes
yes
* B A N N E D *
yes</TD></TR></TABLE>
why thank you sir :]
