** EM1 Rear sway bar onto a EJ8 **
Old Apr 12, 2014 | 12:38 AM
spaazm's Avatar
Default ** EM1 Rear sway bar onto a EJ8 **
Hey guys as the title states haha..
Just wondering would i need to add an ASR rear subframe if i add a em1 rear sway bar?! People say yes & no.. Like put the ASR subframe with the RSB so that the oem subframe doesn't twist...
Most likely get a ASR but just wanted to know peoples thoughts on running the sway bar without it!
Cheers guys!
Old Apr 12, 2014 | 01:22 AM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: ** EM1 Rear sway bar onto a EJ8 **
No, you don't need to for an OEM SI sway bar. Anything larger than OEM, you should.
Old Apr 13, 2014 | 11:13 AM
SDej8's Avatar
People say you don't, but I did just for peace of mind. Asr brace is nothing compared to repairing a torn subframe. Also, keep in mind that the Si did come with factory reinforcement for the subframe that isn't present on the Ej8
Old Apr 13, 2014 | 04:13 PM
senpai's Avatar
I am unaware of this - references?
Old Apr 13, 2014 | 04:50 PM
NotARaCist's Avatar
Yeah, as far as I know, the part numbers for the rear subframes are the same...
Old Apr 13, 2014 | 04:54 PM
B_Swapped93's Avatar
Pretty sure the sub frames are the same across the trim leves of the 6th gen civic the integra Type R is a different story.
Old Apr 13, 2014 | 08:09 PM
SDej8's Avatar
My bad, I was thinking of the ctr bar and ctr factory reinforcement. Em1 subframe is same as ej8 but I'd still get the asr.
Old Apr 13, 2014 | 10:17 PM
98civdx's Avatar
Master Detailer
It didn't, the only Civic to have a reinforced subframe is the CTR.
A Si sway bar will bolt onto a EJ8 using almost all factory components. You will need 4 bolts/washers/nuts.
Possibly a drill/10mm drill bit if you do it the way I did.
xXSanderXx
Feb 16, 2012 09:24 PM
Dr. Willy
Sep 2, 2008 05:26 PM
amej8
Jun 17, 2008 06:16 AM
eMpAtHy
May 19, 2005 10:09 AM
