rod knock / spun bearing or paranoia?
So got to listening and my engine sounded funny, so did some investigating and it sounds like a bottom end knock.
Or I could be insane.
Knocking sound 2000 EL: http://youtu.be/Vkbc0p4SsFY
If it is the case I've sourced a d15b for $200 locally.. .just will need to find someone to put it in.
Still haven't solved my idle issue either.
That's not a happy, nor a healthy motor.
Do a compression test, and an oil change. Inspect the old oil for any metal flakes. If you spun a bearing, there will be metal flakes.
s1ngle
Apr 13, 2005 09:49 AM
