ls vtec is in but wont run right HELP
Old Oct 29, 2002 | 08:02 PM
ls_vtec_b18a1's Avatar
Default ls vtec is in but wont run right HELP
this is what i got a ls block with b16 pistons running like 11:5:1 compression with a b16 head and the the oil lines r ran and the ecu is a pr3 with a mugen chiped ls program with the fuel curves, and 4500 vtec with 8500 rev limit and the 2nd o2 and knock senor taken out. i can get the car to idel fine but when it hit the gas it like its laging, it rev's slow and boggs real hard. i pulled the plugs and it acts like it running too rich like to much fuel is beig dump in. or is this a timing or vacuum problem. o and the air fuel gauge reads all the way to the rich side at idel but when i punch it and let off it goes to starch and then back to rich. whats going on here?
Old Oct 29, 2002 | 08:05 PM
Chugger's Avatar
Default Re: ls vtec is in but wont run right HELP (ls_vtec_b18a1)
switch your map and tps plugs this might work
Old Oct 29, 2002 | 08:25 PM
Default Re: ls vtec is in but wont run right HELP (Chugger)
ok thanks ill try that
Old Oct 29, 2002 | 09:28 PM
Phoenix1's Avatar
actually, switching the map and tps plugs won't allow the engine to idle, it will just rev up until u start it. you may want to check the vacuum reference for your pressure regulator, as well as proper connection of all fuel lines. is the engine is running that rich, something may be causing it to run with too much fuel pressure, or maybe something is wrong with the fuel maps on your chipped ecu. try using a stock ecu and see what happens
Old Oct 29, 2002 | 10:14 PM
dragonrcr's Avatar
Default Re: ls vtec is in but wont run right HELP (Group7hondawerx)
ya but depending on the year some of the map and tps sensors look alike and will interchange this happend to me today and once switched it ran great
Old Oct 30, 2002 | 10:52 AM
Default Re: ls vtec is in but wont run right HELP (dragonrcr)
Old Oct 30, 2002 | 07:18 PM
it was the timing thanks guys
Old Oct 30, 2002 | 08:53 PM
Chugger's Avatar
cool good to hear its fixed
Mjm2392
Oct 31, 2013 02:44 AM
97grnrs
Nov 6, 2006 06:42 PM
redlseg
12
Aug 12, 2005 04:44 AM
Hatch8
Oct 25, 2004 06:30 PM
1niceSi
Jul 1, 2004 05:55 PM
