bad oil leak, what is this and how to fix?
Old Apr 8, 2014 | 03:14 PM
ex99civictears's Avatar
Icon2 bad oil leak, what is this and how to fix?
This is a 1999 EX, D16Y8. It had been sitting all winter. Just added oil and started it up, let it idle and drove it around the block. Then noticed that oil is leaking badly. Badly enough to question whether it could be driven to a repair shop.
It did leak last year, about a quart every 2-3k miles if I recall right.
Does anyone know where the leak is coming from, from these photos? I could try to take better photos. Where should I go from here?
Last year it looked like a leak where the camshaft joins the head but I wasn't sure... was really hard to tell. (see that oily bottom left camshaft nut) Now it looks to be leaking badly at that bolt that holds on the... timing belt cover? I'm not knowledgeable.
Any advice would be highly appreciated.
Old Apr 8, 2014 | 03:17 PM
Default Re: bad oil leak, what is this and how to fix?
More photos:
Old Apr 8, 2014 | 03:30 PM
slomofo's Avatar
GDD Member
It might be a cam seal, but I doubt it. It's most likely the valve cover.
Remove all spark plug wires, loosen all the valve cover bolts, remove the upper timing cover, then tighten up all the valve cover bolts & put plug wires back in, then start the car and observe the leak. You might have to rev the engine up a little bit to get it going, but my money would be on the valve cover.
Old Apr 8, 2014 | 03:31 PM
Fishbone Fan's Avatar
Pics are almost too close up. Clean your entire engine and drive it to renew leak then post pics that are not so close up or at least a mix of close and further back to provide a better reference.
Off hand it looks like it might be either a leak from the valve cover or oil pump.
Old Apr 8, 2014 | 03:38 PM
slomofo's Avatar
GDD Member
Would an oil pump emit oil that high up? The pics show oil on the timing cover outside of the water pump and at the base of the valve cover. Not trying to call you out or anything as I'm still fairly new to Hondas, just asking.
Old Apr 8, 2014 | 04:03 PM
My first guess is the valve cover. If there is oil on top there is most likely oil below (by dripping + gravity) and that's why I suggest he cleans the entire engine. I don't feel strongly he has an oil pump leak and I honestly can't say weather or not it would be up that high or not as I have only read about them and never experienced one myself. However, if it doesn't turn out to be a valve cover leak it gives him another place to look.
Old Apr 8, 2014 | 04:11 PM
slomofo's Avatar
GDD Member
Ahhh, good idea, thanks for the clarification.
Old Apr 8, 2014 | 06:35 PM
JoeSatov's Avatar
Too high for oil pump; I agree with possible valve cover leak. As already suggested, pull off that upper timing cover and take a look. The cam seals I've seen fail generally leak pretty agressively and drip out of the bottom of the timing cover
Old Apr 8, 2014 | 07:24 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The real PITA if it's the cam seal is oil getting on the timing belt basically means new timing belt is a must, not just a seal repair.
Old Apr 8, 2014 | 09:21 PM
slomofo's Avatar
GDD Member
If the cam seal comes off, the belt has to come off first, so belt replacement seems like it'd probably happen with the cam seal anyway, no?
Old Apr 9, 2014 | 02:42 AM
JoeSatov's Avatar
Ya, cam seal leak will coat your belt in anti rust....but me thinks it's more likely valve cover. The oil is leaking through about level with the cam seal, and there is nothing below the cam to carry the oil straight over like that.
I have been wrong before...but I am sticking to the valve cover gasket
flanker
Jan 21, 2015 07:06 PM
caliskier
Apr 14, 2012 03:53 PM
DUKE LADUKE
13
Apr 1, 2010 12:41 PM
SIRef9[831]
Nov 4, 2004 10:01 PM
Hippie
Oct 14, 2002 03:35 AM
