Why hard to start the motor when warm?
New Battery. Alt is charging. No issues at cold start, even during the winter when it's 35 degrees outside. First crank, starts perfect and strong.
Once the car is warm, let's say I have to make a stop at Walmart after an hour drive. 20 mins later, start the car. The engine have a hard time starting. It cranks fine. But it's like it has a hard time lighting up.
I read somewhere that SRI could be the cause of it because of the heat. And/or something to do with fuel flooding, somewhere, something like that, again, perhaps SRI related.
Spark plugs are 60K miles est. Do you think it's SRI related?
Thoughts, ideas, solutions, suggestions?
not sure what SRI is
but with engine cold pull plugs and make sure they're not soaked or fouled, be sure to torque them 1/4 turn past hand tight
with engine cold check coolant in radiator, make sure it's not low, if it is you have a leak, possibly headgasket
with engine warmed up I'd pull each plug wire off the spark plug and check to make sure the engine loses some power when testing each cylinder, this indicates a good plug wire and plug
you could always do a radiator pressure test to verify leaks and compression test to verify good/bad piston rings/valves
on my 98 ex that I bought used it had stripped headstuds so whenever it warmed up the head would partially lift and caused coolant to go in the cylinder. I also had white smoke coming out the exhaust.
If you know your engine is fine it could easily be a simple electrical issue.
Cam and or crank sensors are the most common failure on that vehicle that exhibit the behavior you are describing. Next time you have a hard start issue,look at the tach and see if the needle is moving a little. Cranking rpm is generally about 200-400rpm so you wont see much movement while cranking,but the needle should be moving. It would be even better if you have a scanner or obd2 tool to connect so you can monitor the rpms.....
You'd need a scanner to verify that.....
lilxvtecxpwr
Jan 15, 2003 11:21 AM
