spun bearings-what causes
Old Oct 29, 2002 | 07:27 PM
B pwr's Avatar
Default spun bearings-what causes
im possibly getting a b18c block by nextweek, pretty cheap, reason being- spun bearings in 1 and 4 connecting rods.
physically i havent seen yet, from what the owner says the crank will need turning or replace it, i assuming the rods maybe trashed too, but it will be getting rebuilt anyway.
What actually causes bearings to spin? in this case its a bonestock block.
could it be highmiles(woreout) or improper clearances if he had every rebuilt it-(will ask ) oil maintance or i think high rpm abuse.
ive never seen one, just curios as to why that happens?
any posts welcome.
thanx
Old Oct 29, 2002 | 07:40 PM
LudeyKrus's Avatar
Default Re: spun bearings-what causes (crxpwr)
W/ the H23 Prelude, they have longer rods, making for a bad r/s ratio. When revved too high, they tend to spin bearings easy(or throw a freakin rod!). As far as I've ever heard, it's usually high RPM's.
Old Oct 29, 2002 | 09:02 PM
HotWheelz's Avatar
lack of lubrication under extreme temperatures will cause the bearings to "stick" to the crankshaft and then spin ... or another method is under extreme reving the connection rod bolts will strech making the connecting rod holder not perfecly round but oval.. this added gap will then cause the ability of the bearing to walk and thus spin also..
so basically have very tight and tough rod bolts.. plenty of good lubrification (good oil) and also check the clearances on your main bearings to "PREVENT" this from happening....
I think i'm right ? hhhahahaha eh guys ?
Old Oct 29, 2002 | 09:09 PM
JG ENGINE B18C1's Avatar
Default Re: spun bearings-what causes (HotWheelz-turboh22dx)
same thing happened to me but it was only the #1 bearing and the rest was fine, but i heard if you take hard corners it could creat the problem of spuned bearings,correct me if im wrong.
Old Oct 29, 2002 | 09:18 PM
texan's Avatar
Default Re: spun bearings-what causes (JG ENGINE B18C1)
primarily it's lack of oil pressure. So yes, potentially hard cornering under full throttle with a non-baffled oil pan could starve the bearings of the oil pressure necessary to maintain the film of oil between the parts.
Old Oct 29, 2002 | 09:30 PM
earl's Avatar
Well done
Old Oct 30, 2002 | 07:58 AM
MikeMAN's Avatar
Default Re: spun bearings-what causes (earl)
Well done
a lot of times these engines have been run completely out of oil, (people who don't keep their eye on maintenence), so make sure that there isn't anything else wrong.
mike
Old Oct 30, 2002 | 11:36 AM
B pwr's Avatar
Default Re: spun bearings-what causes (MikeMAN)
ok, good info, to all those above thanx for responses.
Old Oct 30, 2002 | 11:45 AM
CHEETAH's Avatar
mike
or for race cars, the oil pump decides to take a **** goign down the track, you dont catch it early enough she's spinning, talking aluminum foil is what you're gonna end up pulling from big end of rod.
greg
hybridmiklo
Jan 27, 2012 05:40 PM
90ZCREX
Sep 3, 2011 11:47 PM
Lude@Heart
Mar 5, 2009 09:12 AM
b18sihatch
Apr 18, 2007 06:56 PM
HX_Guy
Jul 20, 2001 07:30 AM
