Fender Ties?
Old Apr 5, 2014 | 11:53 AM
ZenDog73's Avatar
Default Fender Ties?
My 94' EG Si Honda front fenders are no longer holding the front bumper. The connection point for connecting bolt is worn weathered warped & weak! need something to hold it together. I've seen photos of other civics this old with brackets or ties of some sort, holding them together. Anyone have a clue on where to acquire some? thx...
Old Apr 5, 2014 | 12:05 PM
Japperson97's Avatar
Default Re: Fender Ties?
use a Christmas tree bit and drill a new hole and then put a threaded bracket and bolt it together. and spray some primer so it doesn't rust on the new hole you made.
Old Apr 5, 2014 | 12:17 PM
ZenDog73's Avatar
Thx, i'll give that a shot.. i figured i'd have to drill holes, spraying some primer is an idea that i missed.. thx
Old Apr 6, 2014 | 09:29 PM
Hidenplanvew's Avatar
Primer isnt waterproof... You would be better scuffing it up alittle and just going to spray paint. Unless it its Epoxy primer, that is waterproof but most rattle cans arnt epoxy
Old Apr 6, 2014 | 09:33 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
use the self etch primer in a can, it's designed to bond to bare metal, then top coat with a quality automotive spray paint, dont use household spray paint, even rattle can automotive paint is far better then that junk
Old Apr 6, 2014 | 09:35 PM
this stuff is surprisingly good, I've been using it for years
Old Apr 7, 2014 | 12:32 PM
rattle can automotive paint is still spray paint... Its all junk in my mind, I would do it right the first time. Primer (except epoxy)tho is porus and will absorb water so it needs to be covered bu something that isnt.
Old Apr 7, 2014 | 06:56 PM
I used it while I was doing all the body work to my car and was still driving it, didnt have a single issue with rust. The reason the self etch is relatively recent in the cans, is they had to invent a can the stuff wouldn't etch through. I have a lot of experience with the duplicolor self etch, I've been very happy with it
724chris
May 26, 2010 12:34 PM
JDM-KIDD
Paint and Body
Oct 23, 2009 01:27 PM
98vtec
Paint and Body
Nov 19, 2008 05:21 PM
Whatislove
Honda Civic (2001 - 2005)
Aug 21, 2008 01:18 PM
1badassEG
Paint and Body
Oct 17, 2007 08:04 PM
