What fmu disk with 450cc?
Using 450cc injectors, is a 4:1 disk suitable enough for 12-13 psi? I heard jinxproof had a past setup where he used 440cc , 12:1 fmu, and afc to tweak the fuel, but the fuel presure sounds too outrageous for high boost applications. Any ideas?
i would say 12:1 to be safe, but there is one below the 12:1 that lots have used just fine ( i just cant remember if its 10:1 or something)
mike
mike
Use a 6:1 and tune the fuel out.. better safe than sorry.
I'm running a 12:1 with 320cc injectors and no AFC... and I have a sluggish idle at times...
Use the 4:1 along with an afc and you will be fine. I've been using 370s with a 6:1 and afc with no problems at 13 psi, except traction. 13.7@109mph can we say absolutley no traction.
12:1 with 450s?!! he wouldn't even idle!!
you use an 8:1 with 310s... maybe a 6:1 or 4:1. not sure.
do not be gay. use the VAFC and 450's. that is all you need. no other pieces.
actually, it would idle fine and be great until the computer went into closed loop and then it would bog like a madman and probably die.
