valve cover bolt won't tighten
Old Apr 1, 2014 | 02:04 PM
ROB77's Avatar
Default valve cover bolt won't tighten
I have a 1993 Honda del Sol SI 1.6 liter I recently changed the valve cover gasket now the 2 outside bolts in the front will not Tighten the bolts are fine I believe it is stripped in the block curious if anybody knew what size tap I need to use to make this repair it is leaking pretty bad I need to get those tight and any suggestions are greatly appreciated
Old Apr 1, 2014 | 03:05 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: valve cover bolt won't tighten
http://www.justanswer.com/uploads/am...6_timing_1.gif
Also, I believe you mean stripped in the head not the block.
Joshgb
Mar 10, 2020 09:32 AM
liquidzorch
Aug 16, 2013 08:09 AM
hcivic99
Jun 8, 2005 06:15 PM
Cuong-nutz
Apr 13, 2005 09:39 PM
illusion
Feb 27, 2002 03:17 PM
