98 civic lx front passenger window issue
Old Mar 24, 2014 | 08:52 AM
eksedan7198's Avatar
Default 98 civic lx front passenger window issue
When I purchased my civic the guy I bought it from told me that the window hadn't worked because of some "Electrical" issue. I've noticed that every other window I use using the master switch dims the vehicles lights when they are on (drawing power) but when I try to roll down the front passenger window it doesn't do that. I've also noticed that when you try rolling down the passenger window with the passenger switch it attempts to roll up but not down... any solutions to this before I throw a bunch of money and frustration into this problem
Old Mar 24, 2014 | 08:58 AM
bamaland601's Avatar
Default Re: 98 civic lx front passenger window issue
either regulator or motor is pretty much all that i could recommend.
if you want to test the switch, pull a back door panel off and see if the front switch will roll the other one up or down.
Old Mar 24, 2014 | 10:01 AM
Will the rear window switch fit on the front door?
Old Mar 24, 2014 | 03:35 PM
it should be the same plug, only the master is different
Old Mar 25, 2014 | 03:58 PM
I just swapped the rear passenger switch with the passenger switch and it didn't fix the problem. The switch isnt the problem.
Old Mar 26, 2014 | 06:24 AM
Hatster89's Avatar
I know it may be tedious but I would try switching motors out. I had similar issue but due to larger problems I ended up replacing the entire door for my fix.
Old Mar 26, 2014 | 08:58 AM
I pulled a window motor from the junkyard a while back and installed it and still no luck. Since it did come from the junkyard there was no guarantee that it wasn't already bad when I bought it. Just making sure... will the rear window motor fit the passenger front window??
Old Mar 26, 2014 | 10:15 AM
Former User's Avatar
Window issue - Check for a broken wire at the connectors in the driver and passenger side door jambs.
Old Mar 26, 2014 | 12:47 PM
I just check the passenger door and some of the wires are showing copper through, I've only checked the passenger side so far.
Old Mar 26, 2014 | 12:59 PM
You'll probably find one broken wire in the driver's door jamb.
Old Mar 26, 2014 | 01:04 PM
Is that that rubber piece between the door and body of car? And if so how would I go about getting to it?
Old Mar 26, 2014 | 01:08 PM
Pull the rubber boot away from the connector to expose the wires.
Old Mar 27, 2014 | 06:25 AM
I'll let you know what I find as soon as I get to it! (Today is my birthday!)
Old Mar 27, 2014 | 07:56 AM
On that rubber boot there are 2 green objects correct? And what techniques do you recommend for taking that off without damaging anything?
Old Mar 27, 2014 | 08:53 AM
Just pulled the rubber boot away and sure enough you're right again Ron! One wire is broken later today im going to try and connect it back and hopefully it works . The wire that I found broken was blue and yellow.
Old Mar 27, 2014 | 03:52 PM
The wire was the problem!!! Had to use heat shrink to bypass the harness because the wires had broken off inside. Nonetheless everything works!! Window is fully functional again!! Thanks Ron!
Old Mar 27, 2014 | 04:14 PM
girliehonda
Honda Civic (2001 - 2005)
10
Oct 16, 2016 03:32 PM
einzelherz
Aug 26, 2013 06:41 AM
hondapwr
Jul 17, 2009 05:30 PM
BauleyCivic
May 1, 2005 04:42 PM
