98 Civic Ex/D16Y8 timing/distributor issues
Old Mar 23, 2014 | 10:30 AM
tlarimer's Avatar
Default 98 Civic Ex/D16Y8 timing/distributor issues
Background on the vehicle:
1998 Civic Ex sedan 192,xxx miles, 5 spd
It's my brother inlaws car, been sitting since early 2011, failed smog and was leaking fluid out of every seal and gasket.
He had the distributor replaced pre-2011 with an aftermarket/parts store distributor, only marking legible are TD and below that 2222.
Fast forward, he brought the car over to have me fix all the seals, gaskets, leaks, etc. I noticed the distributor was rotated all the way back, away from the front of the engine, bottomed out on it's adjustment, didn't think much about it at the time.
I replaced all seals, gaskets, timing belt, waterpump, etc. and know that the mechanical timing is set right, I even pulled the upper timing cover off again to check after I couldn't adjust the timing to the correct mark.
I jumped the service connector in the passenger footwell, hooked up my timing light, restarted car and rotated the distributor to set the timing, it bottoms out again and timing is not quite to the first mark closest to the TDC mark. I shut everything down, pull the upper timing cover and check mechanical timing, dead on where it's supposed to be. TDC mark on crank pulley lines up and both marks on the cam sprocket are flush with the top of the cylinder head.
I don't have another distributor to test on it, but I am really leaning towards this aftermarket distributor being the culprit.
I can't think of any tests that would get me anywhere, because the dist works, just can't adjust the timing to within specs. I am really baffled at this point....
Any advice or suggestions?
MastaFlyMason
Oct 2, 2016 02:53 PM
bnwbass
May 14, 2016 12:37 PM
deving916
15
Mar 28, 2012 05:38 AM
johnbrooke86
Aug 23, 2004 04:49 PM
krazn
Feb 22, 2004 11:11 AM
