New key is stuck
Old Mar 19, 2014 | 05:50 PM
buster97's Avatar
Default New key is stuck
97 civic m/t (no sensor on key)
went to honda bought a new key and the guy said that the door and trunk will be the same but the ignition will be hard ....
go home gonna test the key out(havent drove the car in a month or so )
slips right into the ignition and goes the 3rd stage smoothly but wont start cause battery is dead
i can move my key easily through 1-2-3 and can push it in on the 1st position but i cant twist it all the back to release the key any suggestions or comments????
could it be a issue with a dead battery ? should i go mid evil on it with some pliers ?
Old Mar 22, 2014 | 06:35 AM
99elcoupe's Avatar
Default Re: New key is stuck
try jiggling the **** out of the key as u turn it happens to my 99 civic once in a while and can usually get it out that way. believe its a problem with the ignitions
Old Mar 22, 2014 | 06:56 AM
bamaland601's Avatar
fix the battery issue first.
isnt there a key release button on the column? coulda sworn all manual trans cars had key release lock button..
Old Mar 22, 2014 | 08:50 AM
NotARaCist's Avatar
I never narc'd on nobody!
96-98 Civics definitely don't have a key release button. I don't believe 99-00 do, either.
OP, try pushing the key in while rotating it backwards towards OFF.
Jmaldonado
Honda Civic (2006 - 2015)
Aug 7, 2025 02:27 PM
2001actn
Honda Civic (2001 - 2005)
Nov 10, 2018 10:48 AM
bopbop93030
Jan 11, 2012 09:56 AM
Honda_Noob_94
Audio / Security / Video
Aug 29, 2010 02:27 PM
GroundZer0 336
Apr 10, 2003 07:52 AM
