2001 PRELUDE WILL NOT IDLE, STALLS. HELP
Old Mar 18, 2014 | 04:46 AM
ECKOHOMIE33's Avatar
Default 2001 PRELUDE WILL NOT IDLE, STALLS. HELP
okay guys, had a thread awhile back, same issue just never resolved, start the car, runs for a few minutes, idle starts dipping under 1000 rpm's and shortly after comes up one last time above 1500 and stalls out, after it stalls you can crank and crank and it sometimes will start and idle very low, sometimes will run for 20 minutes and idle very low as well. adjusting idle screw doesn't change at all. mostly when you hit the gas and it comes back down to sit at idle it will stall. went through everything from tps, map, tps, checked all vacccum hoses, compression is good, egr valve not stuck open at idle, cleaned vtec screen and tested solenoid being stuck on at idle as well. car will run and drive, has power, just will not idle when warm! o2 sensors operating and no codes at all!
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
invasian_boy
Jul 15, 2008 12:59 PM
spock_rocker
Oct 17, 2007 08:11 AM
turbotime
Oct 24, 2005 12:01 PM
