Kill switch install
Old Mar 16, 2014 | 01:23 PM
Kevinio's Avatar
Default Kill switch install
I'm busy with a kill switch installation in a friends car. The only thing I want to find out is which wire of the alternator I have to switch down to switch of the engine. We already know it's not the blue one, but we don't want to cut also the other ones. Does anyone of you know which one we have to take? It's an ODB1 B18c6 engine
Old Mar 16, 2014 | 03:41 PM
fcm's Avatar
fcm
Old Fart
Default Re: Kill switch install
Car will run even without an alt. as long as batt. has a charge, put the switch on something else, [ground for PGM-FI Main Relay, fuel pump relay control lead from ECU/ECM, a power lead for the PGM-FI Main Relay, power or ground for the ECU/ECM power for distributor assembly]. 94
Old Mar 16, 2014 | 04:28 PM
Vagitarian's Avatar
Thats a horrible spot for a kill switch, kill the ground to the fuel pump
Old Mar 17, 2014 | 04:27 AM
Kevinio's Avatar
I've taken ICM1 on the ECU to switch off now, works way better. When I'm home I will make some pictures of the schedule.
jjos
Audio / Security / Video
Apr 26, 2016 02:09 PM
RINZY
Oct 24, 2013 05:00 PM
Serge L
16
Feb 2, 2012 10:08 PM
Mr.Death
Jul 21, 2008 07:11 PM
cltitus
Jan 7, 2007 11:09 AM
