Can't Figure Out Why Car Keeps Dying
A few days ago my ek hatch wouldn't start. It started to crank but all the lights dimmed down to almost nothing and it wouldnt crank so I got stuck.
Got my battery (somewhat) tested. It had 0% charge and my mechanic said it probably had bad cells so I replaced it.
1 day later, it did it again and the battery is dead again.
A few things to know:
1. I tested the alternator myself by pulling the battery out while it was running and it didn't die. (I know this doesn't tell you a lot but it shows me it works to some capacity atleast)
2. Prior to the 2nd battery dying, my battery light on the cluster would come on until I revved the engine and would go back off.
3. Starter is starting to die (grinds, sticks once in a while)
4. It is able to be jumped.
TL;DR - Battery dies, dying starter and car won't charge.
So anyone have any idea of why it keeps dying? I think it's the alternator not keeping up but want more opinions before I throw parts at it.
The easiest way to check your charge system is with a voltmeter, set it to 20v and check the battery with the engine off should have 12 to 12.6v then whit the engine running check again you should see 14.0v - 14.6v.
Check the alternator belt adjustment. Any CEL? A bad ELD can do this.
start your car and while the motor running (at Idle) turn your a/c on high and you headlights on high beam. Than check the voltage at the battery. You should have about 13.8 volts at the battery. This normally means that you have a weak alternator or your voltage regulator is bad.
