96 prelude si sudden starting issue
Old Mar 11, 2014 | 12:36 PM
S13SR20's Avatar
Default 96 prelude si sudden starting issue
Little brother is driving my prelude. For the time being.
All of a sudden prelude won't start.
It won't even turn over. No starter activity.
Known:
-battery has charge.
-starter is fine; verified by jumping solenoid wire from engine bay.
-it's not the ignition switch; verified by jumping starter wire and 12v wire (voltmeter verified) after ignition switch, before kick panel box. When I jumped 12v wire and starter wire, starter didn't do a thing, which it should have since starter is fine.
-jumped both clutch switches. No change.
-checked 7 amp fuse at drive side kick panel. It's fine.
I was thinking main relay, but I quickly changed my mind after I turned ignition to accessory and jumped the solenoid wire again. Car started fine and stayed on.
What I want to know, is if there are any other relays or fuses associated with this starting circuit? This is getting really annoying considering I can jump the starter and the car runs fine.
Old Mar 12, 2014 | 01:24 PM
S13SR20's Avatar
Default Re: 96 prelude si sudden starting issue
Someone help !
Old Mar 13, 2014 | 08:18 AM
ECKOHOMIE33's Avatar
check the starter relay under hood
Old Mar 13, 2014 | 09:48 AM
GSR_BUM's Avatar
bad ground possibly
Old Mar 13, 2014 | 06:32 PM
S13SR20's Avatar
I didn't know there was a starter relay under the hood. Is it labeled starter relay or is it called something else
2x0
Apr 29, 2018 09:35 AM
slow_sihatch
16
Aug 4, 2015 04:35 PM
cksnah252
12
Sep 9, 2014 07:51 AM
SlimBB4
Nov 1, 2010 01:12 PM
92hondalude
Jul 14, 2009 08:29 PM
