Oil cooler
Old Mar 11, 2014 | 09:00 AM
JDMequalslife's Avatar
Default Oil cooler
Car is a 92 civic hatch back, motor is a zc/z6 with p29 pistons.
I know with he higher compression the cars gonna run a little hotter, i am running e85 but still worried about temps.
I am gonna drive the car hard, drag days, drag racing. the car does everything. expect daily driving. question is can a stock oil pump(not ported and shimed) handle the oil cooler without loosing pressure and starving the engine? i could install in and see what the oil pressure gauge tells me but i rather here from other peoples who might have done it
thanks guys
Old Mar 11, 2014 | 09:01 AM
Default Re: Oil cooler
http://www.ebay.com/itm/PERFORMANCE-OIL-COOLER-KIT-Honda-Civic-Accord-b16-d15-/180675513169?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a11198b51&vxp=mtr
this is kinda the set up i want. someone said go-autoworks makes one?
Old Mar 11, 2014 | 09:53 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I really don't think you need an oil cooler for what you're doing. It's a NA D series that you're gonna drive hard for short periods of time. What kind of compression are we talking here? 13:1?
Still...you don't need a cooler. But...I have seen a few road course cars with coolers. I don't believe anyone upgrades their pumps. It's just moving another 1/2qt of fluid thru some lines and a cooler.
Old Mar 11, 2014 | 02:35 PM
Yes compression is gonna be around 13.1. We do drive through so cal canyons which can be for ten minutes at a time up hill. It does sound short but couldnt the temps still rise and cause oil not to lube as well?
So starving shouldnt be a problem?
Old Mar 11, 2014 | 02:44 PM
B_Swapped93's Avatar
You're not doing any real tracking so not need if you were doing time attack then maybe but even I wouldn't run one on my dc2. if you haven't already invest in a good rad/t-stat water wetter etc.
Old Mar 11, 2014 | 02:51 PM
i plan on going to button willow and doing track days so its gonna be pushed hard. Im using stock rad my friend has a dual core and his car seems to run hotter then mine. themostat will be upgraded, also go gonna try water wetter. Have a thermal gasket to keep manifold temps down, heat wrapping exhaust manifold, heat reflective tape will be on the manifold, oil pan and also the oil filter.
blitzman
Apr 25, 2016 02:30 PM
goodolcipro
Honda Civic (2006 - 2015)
Sep 19, 2011 07:57 AM
teler86
Sep 21, 2006 07:34 AM
street dreams
Apr 2, 2005 12:17 PM
90crxzc
Dec 6, 2003 01:36 PM
