rear disk brake help
took my brakes apart greesed sliders
the sliders keep wanting to push out is that normal?
put everything back together but now the hub wont turn im guessing because the sliders keep pushing out
i made a video here https://www.facebook.com/photo.php?v...49458765178882
i havnt driven it yet but i pressed the brake pedal a bunch of times but didnt do anything
the sliders will keep pushing out because there is trapped air in the pocket. slowly push the slider pins in. Is the brake rotor even or are the pads even? Sounds to me the pads are worn out un-evenly.
^^ what he said.
I'm also guessing they may not be seated properly. You could take it around the block and see if the problem goes away.
Keep in mind there is never anything holding the pads off the rotor. The rotor simply kicks them off as it gets up to speed.
R_ACE1
12
Aug 16, 2009 12:53 PM
JDM TypeR 307
Feb 27, 2004 06:07 PM
