Transmission & Drivetrain Gearboxes, Differentials, Clutches
Hydro LS 1-2 sleeve in cable B16 transmission?
Old Mar 10, 2014 | 11:03 AM
F22Master's Avatar
Default Hydro LS 1-2 sleeve in cable B16 transmission?
I am currently rebuilding my cable S1 B16 transmission and the 1-2 sleeve is pretty worn down. I have a spare 1-2 sleeve from a hydro LS transmission lying around that is in great condition. It fits great on the cable transmission hub, and everything else looks the same. Would there be any reason not to use it? Anything else I should worry about? I have the LS hub, if I need to use it that would be no problem too.
Thanks!
Old Mar 10, 2014 | 02:52 PM
David @ Synchrotech's Avatar
Default Re: Hydro LS 1-2 sleeve in cable B16 transmission?
Use the cable S1 hub with the hydro LS 1-2 sleeve and it will be fine.
Old Mar 10, 2014 | 03:58 PM
F22Master's Avatar
I tried to not bother you with more PM's, but you always seem to have the perfect answers to my questions! lol
Thanks again!
tooslohatch
Sep 29, 2014 07:27 AM
Junkyard
May 15, 2009 09:07 PM
pblockfinest
Nov 7, 2008 08:33 AM
Dasfinc
Apr 28, 2008 07:33 AM
Atheist
Apr 8, 2005 07:09 PM
