98 Civic Timing Question
Old Mar 9, 2014 | 11:00 AM
Ej8 d16's Avatar
Default 98 Civic Timing Question
I installed a new flywheel on a d16y8. While doing so I rotated the crank. When I finished, I just rotated the crank pulley counterclockwise to get the cam gear in the right position, with the word up in the 12'o clock position. Since I didn't touch any aspect of the timing belt, other than rotating it, should I leave it as is or consult a mechanic.
I haven't tried to start the engine because I missing components.
Thanks in advance.
Old Mar 9, 2014 | 01:37 PM
98civdx's Avatar
Master Detailer
Default Re: 98 Civic Timing Question
You're fine, Simply rotating it over won't affect the timing.
Old Mar 9, 2014 | 01:50 PM
NotARaCist's Avatar
I never narc'd on nobody!
Yep. If you haven't touched the distributor or timing belt, you aren't changing the timing at all.
Old Mar 9, 2014 | 08:59 PM
Ej8 d16's Avatar
I received the long block from a friend without a distributor. I used my distributor when I swapped out the engine. I know the engine is on "time" because I tested it while on the car and took it out myself.
Should I look up write-ups for the distributor issue?
Old Mar 9, 2014 | 09:04 PM
NotARaCist's Avatar
Distributor issue? What distributor issue? You just need to buy/borrow/rent a timing light and set ignition timing.
Old Mar 9, 2014 | 09:41 PM
98civdx's Avatar
Master Detailer
What issue?
Once you get the car running set the ignition timing with a timing light.
Old Mar 9, 2014 | 10:18 PM
Ej8 d16's Avatar
Oh I see. Alright, thanks for the help.
Old Mar 10, 2014 | 06:30 AM
Former User's Avatar
See diagram in FAQs sticky.
bnwbass
May 14, 2016 12:37 PM
jakscivic
Jun 2, 2010 07:29 PM
Jorsher
35
Apr 26, 2010 07:57 AM
handa
Jul 30, 2004 11:19 PM
