Cel 6 need help
Old Feb 26, 2014 | 04:59 PM
$MIKE$'s Avatar
Default Cel 6 need help
Changed my set up a bit and on initial start up I'm getting a cel 6 (ect sensor) I have already changed out the connector and the sensor it's self.
Any other ideas? my only other stuff I have to check is the signals on the ecu side and maybe running wire straight to the ecu, is there a fuse or anything I'm missing?
Set up is a 2001 Gsr obd2b to obd1 jumper hondata s300
B18c5 motor turbo set up.
Thanks in advance
Old Feb 26, 2014 | 05:02 PM
hybridmiklo's Avatar
Default Re: Cel 6 need help
check for 5 volt reference. check ground on plug.
Old Feb 26, 2014 | 05:58 PM
$MIKE$'s Avatar
It's not 5v from my checks it's like 1.7
Does that make any sense I'm not good with electric stuff it can't be sensor I already replaced it, only thing left is ecu or wire from ecu
Old Feb 26, 2014 | 06:25 PM
fcm's Avatar
fcm
Old Fart
Reference voltage should be 5V, check that voltage at the ECU/ECM, [hondata s300] there may be a connection problem, a jumper harness adds a lot of connection connection point to any given lead.
If voltage is good at the ECU/ECM do a continuity test on the lead to find the bad connection point.
If voltage is still only 1.7V at the ECU/ECM, replace the ECU/ECM. 94
Old Feb 26, 2014 | 06:49 PM
$MIKE$'s Avatar
Hoping it's not the ecu but yea I've been reading as much as I can. I figure worse case I can find if it's a bad signal or ground and run it stright to ecu.
I've been wanting a rywire harness anyway
Old Feb 27, 2014 | 10:54 PM
holmesnmanny's Avatar
Check for the same voltage at the map sensor or tps sensor. If the same, the ecu is def toast.
Old Feb 28, 2014 | 01:24 PM
$MIKE$'s Avatar
fixed guess I had a break in the wire in my harness. I ran one from jumper straight to the sensor. I know its kinda ghetto but I am going get a new tucked harness
stenger
Engine Management and Tuning
Sep 18, 2015 08:15 PM
shytdoode
May 20, 2009 03:41 PM
jaha-crx
Sep 24, 2008 09:37 AM
silverboost
Oct 17, 2005 11:21 AM
civic_jdm
Jun 6, 2005 10:18 AM
