94 civic ex wheel stud replacement! Please help!
Old Feb 25, 2014 | 11:53 AM
dirtridernathan's Avatar
Default 94 civic ex wheel stud replacement! Please help!
It's stock disk in the front drums in the back. How do I replace the studs. Mainly the front ones.
Old Feb 25, 2014 | 12:50 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: 94 civic ex wheel stud replacement! Please help!
I can't find it in the FSM but you have to remove the hubs. You will take the caliper off the rotor disk (caliper mounting bolts 80 ft-lbs). You will have to under the 2 screws holding the rotors to the hub (7 ft-lbs), then you have to undo the wheel nut (replace with a new wheel nut), take the hub off and then you should be able to tap the lugs out of the hub and put new lugs in. Then reassemble. The wheel nut I believe is supposed to be torqued to 134 ft-lbs. And then you punch the lip down so it cannot loosen.
This is all off the top of my head so if anyone notices any information missing or incorrect please correct me.
Old Feb 25, 2014 | 02:02 PM
HondaPartsHero's Avatar
Technical Hero
http://civic-eg.com/viewtopic.php?t=...1c385a0f48f510
Old Feb 25, 2014 | 07:36 PM
Thanks! Appreciate the help guys. I'll have to get out there and get it done now!
ewoo
Feb 24, 2009 04:23 PM
panix
Apr 5, 2005 07:55 AM
HCivExoo
Mar 19, 2005 09:05 PM
Tokyo_X-treme_Racer
Jul 20, 2004 08:10 AM
CHONCH
22
Dec 1, 2003 09:21 PM
