95 civic 1.5vtec timing belt?
Old Feb 21, 2014 | 03:51 AM
oreh16's Avatar
Default 95 civic 1.5vtec timing belt?
Hello fellow honda enthusiasts. This probably lame question to ask but i am new to hondas, never had them till last Thursday. I recently got my head gasket replaced and all that hot jazz but sadly my timing belt is pretty loose and im afraid it might skip a tooth.. can anyone show me how to make it tighter so I can do it myself.
Old Feb 21, 2014 | 05:23 AM
Eg.ls.turbo's Avatar
Default Re: 95 civic 1.5vtec timing belt?
Did u install new timing belt and tensioner?
If u did then put cylinder 1 at tdc (top dead center). Put a long skinny stick in cylinder one to help u see when it's at the top and won't go any further.
Then check all ur timing marks to make sure everything is timed.
Next to tighten the belt (assuming u already tighten the tensioner bolt which u already should before turning belt). At tdc turn 3-4 cam gear teeth past tdc or until te belt is loose near the water pump, loosen tension bolt and retighten back to specs. And it should be tighten.
giovannie23
Jul 20, 2013 11:52 PM
WiedemannC
Dec 6, 2010 12:35 PM
jakop92
Aug 31, 2008 07:21 AM
mattatchison
Jun 7, 2007 04:58 PM
eddiecut
Jun 16, 2003 12:10 PM
