Help with 96-00 Cluster Swap
Old Feb 20, 2014 | 08:02 AM
InTheZoneAC's Avatar
Default Help with 96-00 Cluster Swap
I have a 00 ex cluster M/T. I'm wanting to swap in a Si, VTI, or ek4 cluster.
I know people said the si cluster will read faster, but is that the case with any other of these clusters that read 140mph?
I have a d16, would a vss/speed sensor from the b series motors fit and be a direct swap to correct the speedometer issue?
Old Feb 20, 2014 | 08:31 AM
kyden's Avatar
Default Re: Help with 96-00 Cluster Swap
it'll read the same.
Old Feb 20, 2014 | 01:31 PM
Thanks for the replay, just found a post that mentioned speedo correctors, will definitely be buying one.
I've always wanted a different cluster, prefer s2000, but an Si variant will do just fine. Just need to change mileage to match.
Old Feb 21, 2014 | 05:03 AM
kyden's Avatar
you shouldn't need one. an si and normal civics have the same overall diameter tire. you need it with an s2000 cluster because they are a different diameter than what came on civics.
ih8speedbumps
14
Jan 6, 2014 08:06 AM
w00ted
Jul 20, 2007 06:04 PM
mugenpowered
12
Apr 29, 2006 02:01 PM
